Rom for this device
    Rom for this device
    Hi.
    A friend of mine gave me this box.
    http://1-life.eu/?product=1life-tvsmart-box and i cant find any rom for it.
    Can you please help me???
    I will apreciate any help.
    SPECIFICATIONS
    Processor speed: 1.5GHz
    Chipset: RK3188/Quad Core ARM Cortex A9
    RAM memory: 1GB DDR3
    Built-in memory: 8GB
    Operative system: Android 4.2 (Jelly Bean)
    GPU: 4x Mali-400
    Maximum resolution: 1080p Full HD
    Dimensions: 142 x 95 x 21mm
    Weight: 140 g
    Network: Wireless LAN 802.11 b/g/n or RJ45
    Seems like the follow Devices:
    - T-R42
    - CS-918
    - Q7
    The Problem is all have the same Housing.
    Regards
    Neomode
      - T-R42
      - CS-918
      - Q7
      Regards
      Neomode
      That´s my problem.
      I'm going to open the box a see whats inside
        OK, that the Best Idea.
        Please make a Photo of the Front and Back then I am able to Help you more.
        Regards
        Neomode
          Ok neomode.
            Regards
            Neomode
            Hi neomode
            I disassemble the box and i take this photos.
ID:	435313Click image for larger version
ID:	435314Click image for larger version
            Can you help me?????
              HI Guys: This ROM is just for the T-R42 B351_V2.0 pcba board, please don’t flash in other models. How to know you are having the T-R42 B351_V2.0 pcba board. first […]
