I'm a linux geek, so as soon as I've seen someone porting openELEC (or any other linux distro) on our box I was excited and eager to test it.
The first attempt resulted in a broken thing and had to go back to Android.
Right after, the second attempt, was awesome! Everything suddenly worked out of the box! (I've used the kerber version of at xbmc.ru... It's in russian but, for the s89, you are just interested in the link with "s82" in the zip name.)
It was so simple and I was amazed how well the wifi, the ethernet and the overall speed of the box worked.
Honestly it wasn't working bad at all before with Android. I wasn't using games or so, only XBMC. So I can't say it resuscitated the box, it was pretty much alive already.
However I think I prefer the feels of openELEC.
What your experience? Does it worth stay on openELEC? Are there any obvious advantage using Android?(regarding XBMC only, I wasn't using games or other app...)
