1.Add 1080P24Hz support;
2.Support for NTFS/CIFS
3.Change Input method to Latin,and remote can use;
4.Update Play Store;
5.Support for Mele F10 air-mouse
6.Support for Xbox/PS3
7.Change method of Root access
8.Add kill-recent-task function
9.Update xbmc to Gotham 13.2,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
10.Add remote function in Recovery Mode
11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
12.Fix issue->Power-key of Remote might lead to reboot;
13.Improve small probable of blurred screen.
Download here:
Upgrade method:
http://probox2.com/firmware-upgrade-...widget_0_1_0_0
Enjoy it!
thanks,
W2COMP
10-NOV-2014
