Updated CWM Recovery for Cube U30GT Mini and H (May work on other RK3066 tabs)
    I've been using an updated CWM recovery on my Cube Mini. This is version 6.0.1.0 and is touch based. I've used this both flashed on it's own to my mini and also as part of a full flash.
    When flashed as part of a full ROM the tab will boot into recovery, select reboot and the tab should start up. The first start up will probably result in sdcard errors, now the tab is started press the notification to format the internal sdcard and you are good.
    I've not tested this on other tabs but it's been confirmed to work with the U30GT H and will probably work on other RK3066 tabs as well.
    As usual I'd be grateful of any feedback positive or otherwise.
    almost forgot the link
    Recovery 6.0.1.0 Touch (1.8 meg)
    Enjoy
    900Supersport
    freaktab developer
    Hi 900ss the link doesn't appear to be working.
      It should take you to my GDrive where I have shared it.
      Just tested and it works OK for me, could be as I am uploading a ROM Kit based on cubes 1.09 fw
      900Supersport
      freaktab developer
        Re: Updated CWM Recovery for Cube U30GT Mini and H (May work on other RK3066 tabs)
        That'd make sense as I can't access any of your files... I'll wait and check later.
        Sent from my U30GT-H using Tapatalk 2
          Could be the band width too high. If so I'll try dropbox later.
          900Supersport
          freaktab developer
            NOT OWRKING
            Enjoy
            Mine is U30GT- mini like yours. I formatted SD card to 32 bit. copy your recovery.img there.
            Press power and volume up till i se recovery mode, choosed update rkimage from /sdcard.
            nothing happerned. "E:can't mount /update.img, can not found firmware image ore invalid image"
            Currently my mini only show to recovery mode after I switched on power. OWrse off all my pc cant recognised even I used a lot of rk usb driver, still showed yellow triangle at U30GT-M in device manager. I made my win 7 64 allow not diigtally signed driver able to install. Can you help? If my mini can be recognised by PC, I will use RK batch tool and reinstall firmware again.
            Thank you so much
              With the cube switched off, well changed but not on the charger
              • press and hold power for 10 seconds to force the cube off
              • press and hold vol+
              • press and hold power for 4 seconds
              • release vol +, the screen should remain black
              • connect the cube to the PC via USB, it should be detected
              • Install the drives (included in my ROM kit)
              • Start the flash tool
              900Supersport
              freaktab developer
                Works well on U30GT-H
                Thanks for all your hard work. This works well on my U30GT-H and I don't have to worry about my volume rockers failing again!
                  Is this CWM Recovery support about Backup, then Recovery? Because last CWM Recovery not recovery. Always error.
                    It should give backup and restore functionality yes.
                    900Supersport
                    freaktab developer
                      Wish master,
                      I read somewhere, to format ur SD card to NTFS, copy the .img file to it, then put it in ur pad and then copy it over to the nand drive, rename it to update. img and it should come up with "If you want to update..." I tried this and it works fine. kind of snazzy so as not to erase ur data either.
                      hope it helps...
                      Thank you so much
                        Originally posted by cmiuc View Post
                        Wish master,
                        hope it helps...
                        Dear cmiuc,
                        Thanks for your advice.
                        copy which img fieele - recovery img or rooted rom 1.04?
                        mine is u30 gt- mini version
                        Current situation: my win 7 64 bit not recognised, able to off power by press n holding power switch. Once power is on(i tried alot of combinations poweralone, power plus vol+, power plus vol-) my mini went to android logo lay dwon with open stomach and red triangle exclamation. After pressing together power and vol +, went into recovery mode ( blue text line options)
                        I will try with ntfs and will update that anyone with same problem can learn
                          Hello, How i gonna install with the CWM recovery. I have totally no idea with it. Please guide me. Im using u30gt-h v1.10
                            cwm on stock rooted kernel
                            hi! i'm using a mediacom branded tablet. it's called 102 s2. it's a cube u30gt-h device. I tried your rom. It's super! i'd like also to be able to use cwm of your rom on stock kernel. is it possible? thx for your work
                              Yes I think it's possible. Flash just the kernel and recovery from my ROM
                              900Supersport
                              freaktab developer
