Location of the wallpaper in the Cube Talk 9X U65GT
    Hello, I like a wallpaper that brings a ROM and I would keep it. But is not that the system path is ... I will use root explorer ...
    Does anyone know where it is?
    Thank you ¡¡¡
    Here:
    Originally posted by geofferyh View Post
    I have been wondering how to find the default wallpaper, but it might help some to be a bit more specific:
    1. Locate: /system/framework/framework-res.apk
    2. Open framework-res.apk with "Package Installer", select 'View'.
    3. Locate: /res folder/drawable-sw720dp-nodpi
    4. Extract: drawable-sw720dp-nodpi, then 'go to extracted'.
    5. Open: drawable-sw720dp-nodpi
    6. Copy: default_wallpaper.jpg to /mnt/external_sd
    7. Unmount the external-sd card, then...
    8. Open: default_wallpaper.jpg with your graphics program.
    You will see the picture is bigger than the screen. Put in your substitute picture with the right size for your desired resolution. Then, copy it back to where you found it.
    Currently Inactive on Freaktab.com
    I use: MK903V | MELE F10 Deluxe | Roku 3600R
    RIP: MK808b | MK809III | PIPO M9 Pro
      Originally posted by budgetgeek View Post
      Here:
      At the end I found another way:
      /system/priv-app/Launcher3.apk
      Copy it and then opened it with winrar PC and found in the folder:
      And there are ...
