2014 is the year of Windows tablets, as we have seen all sizes of Windows 8 tablets taking over the market that has been dominated by Android and iOS for years. While people are still debating whether 8-inch tablets are too small for running Windows 8, certain manufacturers try to push things even further. That is exactly what has happened here, the Cube iWork 7 is the very first 7-inch Windows 8 tablets on the market.
Key Features
7 inch IPS display at 1280*800 pixels
Weighs 280g, 190.8*111*8.8mm in size.
Intel Atom Bay-trail Z3735G Quad-core CPU, 1GB RAM
Windows 8.1
Office 365 with one year free subscription
16GB of built-in-storage, expandable by TF card
2MP front-facing camera & 2MP rear-facing camera
AAC speaker
Wi-Fi, Bluetooth 4.0
USB host
Micro SD card slot
3500mAh Li-Po rechargeable battery, 4-5 hours battery life
The iWork 7 is not going to win any beauty contests. It is very much the plane Jane of small tablets. There is nothing on this tablet that you wouldn’t have seen before; a plastic rear, black front bezel, and rounded corners. But it feels reasonably well-made., at only 8.8mm it is slimmer than most Windows tablets on the market, and at 280g it’s as light as any 7-inch Android tablet.
The iWork 7 is designed for portrait use. The front is dominated by a 7-inch IPS display at 1280*800px. The bezel on the left and right side of the display is quite small, making the tablet easy to be held in one hand. The relatively bigger bezel up and down makes sure that you have a place to rest your fingers while using the tablet in horizontal mode.
Along the side you will find all the physical controls, ports and slots. There are a 3.5mm audio jack, a Micro SD card slot, a Micro USB port for both data transmission and charging, a Mini HDMI port, and a Power/standby Key on the left side, a volume rocker and a Windows Home button on the top side.
The front-facing camera sits above the display, while the 2MP rear-facing camera sits in the upper left corner of the rear side.
The iWork 7's display is certainly not going to set the world alight. It has a 1,280*800-pixel resolution, which is pretty standard for an inexpensive Windows tablet and enough for the Windows Desktop and for web browsing.
Everything looks perfectly fine if you stay in the Windows 8 interface and the applications installed from the Windows store. If you enter into the traditional Windows desktop, icons, letters, and even dialogs sometimes look too small.
7-inches, 280 grams, 8.8mm thick is, with respect to Windows PCs, very impressive. In terms of consumer tablets it’s average though and the obvious comparison is the iPad Mini2 and the Samsung Galaxy Tab S, both of which are slimmer than 7mm. Still, it’s good enough for a long-term reading session and absolutely fine as a sofa companion and with 7-inches of screen you get much more usability in landscape mode as a mini PC with a Bluetooth keyboard.
One thing that does expose itself more than on any other recent Windows 8 PC is the presence of the desktop. Regular reboots to install patches are awkward. Pop-ups from security software and the occasional feeling that you might have left something running on the desktop constantly remind you that this isn’t a simple tablet. Also obvious is the immature Store. You can find almost everything you need, but the quality is poor. YouTube takes so long to start streaming for example. Some apps just seem to re-start occasionally and there’s poor use of screen space in many cases. This will surely improve over time with more Windows tablets sold day by day, but for now, it is no match for the Apple app store or Google Play.
Portrait mode use is best for thumb-typing and auto-correct in Windows 8 applications is very good. There doesn’t seem to be a way to turn on haptics when typing, if that’s something you like.
As the tablet runs the full version of Windows, you have the luxury of choosing from tablet-specific apps from the Store, or using any traditional Windows application that takes your fancy. This means that, for example, you could forget about Office 365 and use MPS Office, or use the full version of Xunlei Kankan instead of the more limited tablet-specific version.
Because none of the applications above are designed for a touchscreen, they can be fiddly to use. You have to be careful with your prodding to make sure you hit the option you need.
If you do wish to use it as a PC, plugging in a keyboard or mouse should be the right first move, yet it is also tricky as the tablet has no full-size USB port, so you have to make do with Bluetooth peripherals designed for tablets or connect the slate to an OTG adapter. If you feel that the 7-inch display is too small for mouse operations, you can always take advantage of the HDMI port and view things on a bigger Screen. With everything said, unlike the Surface Pro or Acer Iconia W700, the iWork 7 isn’t the tablet that can replace your laptop.
