Polaroid PMID704
Originally posted by reno View PostI bought the same one as well, can we please get some info on rooting this model?
Originally posted by dolorespark View PostIf the 704 is like other (late-model, at least) Polaroids, it's already fully rooted out-of-the-box. Still, you may want to install SuperUser or SuperSU so you can keep track of what's trying to get root access.
I was only able to install superuser and supersu by first installing busybox available from Google play.
Busy box updates existing and adds new Linux commands.
Superuser and supersu when working correctly, will show a popup box when a program first tries to access root.
When you allow access it is trusted and joins a list viewable within the application itself.
Kind of like a firewall to protected area access.
There were a lot of confusing posts concerning semi root. Semi root, IMO, is functionally rooted.
704 does come pre-rooted out of the box.
James (mobile device technician for Phonedoctors)
Originally posted by jhicks74 View PostWould love to have Clockwork mod recovery available for this device.
This contains a bunch of ROMs and stuff William Kleiman built back in October. Drill down to Polaroid->Tools->nandi and you'll find 'recovery.img'. This supports tablets with 9 partitions and a "Home" button. If you have 10 partitions, you can modify vold.fstab to point '/emmc' at 'nandj' rather than 'nandi'.
If your tab has a "Back" button, you may want to use one of my mods of the original - they come in 9 and 10-partition versions. Get them here: https://docs.google.com/folder/d/0B3...J5bF80Yzg/edit
They reference the Polaroid PMID4311 but should work on any Allwinner tablet.
There are currently 3920 users online. 0 members and 3920 guests.
