M8 Video playback problem (NAS)
    I posted my problem on several sites, but still dont have a solution for this. Problem: Video playback (usually MKV files) stops. I use XMBC but tried with several other players and its the same. The videos always stop at the same point which means 2-5 freezes during a movie. After the freeze i need to skip that point manually, start to play few seconds beyond that point and it works until the next freeze.
    Until Now i used SMB share, but now i tried NFS share, and the problem is almost the same. With NFS the movie stop/freeze at the same point but XMBC do not stops playing it, only the screen freezes. (NO sound, screen frozen) but the subtitle goes on. I can call the play menu, and if i click on "stop" button XMBC freezes completely. After this i can only close it from task manager.
    If i copy the same Movie onto an SD card, the movie play do not stops at that pont...
    Here is an XMBC log about the freeze, i renamed it to TXT. Maybe someone smarter than me, can check it, and find out what is it
    xbmc.txt
    Solved!
    It Makes no sense, but after changing my router the video playback is ok.
      it would help others to tell us what brand/model router you had, and what brand/model router that solved this problem
      Originally posted by Still View Post
      Solved!
        Oh sorry. Media boxis M8 square one. NAS D-link dns-320l. The router which was not working well is DS-link WR-1000ND. This one is a Gigabit wifi router. I tried 2 other routers and they work perfectly. TP-link WR-841N and the one i use now TP-link Archer C2.
          Thank you sir.
          I love the TP-link WR-841N. I have two of them. They work great and they are easy on the wallet
