Thank you for your answers.
No video signal "minix neo x5"
I have not been using it for some weeks and now when I try to turn it on, I get just a Black screen. The light is blue but there is nothing on the screen. I connect it to the computer and it recognizes it perfectly. I can install firmwares with no problem at all but it does not matter which firmware I install because I always get the same result "black screen". I do not know if it will be a HDMI problem or voltage problem. Have any of you experienced something similar? i want to use my minix
Thank you for your answers.Tags: None
There are currently 1967 users online. 4 members and 1963 guests.
