Rooting Nexus 7
Originally posted by ZonaMojo View PostMr. Bob, any plans to try and root a rom for the Nexus 7? Sole reason is the max memory is 16GB with no SD Card, therefore I'd like to get rid of a lot of pre-installed apps that came with it and are wasting space.
Warning: removing preinstalled apps may cause updates to fail!
Since I'm getting regular updates I've put off rooting til I see what 4.2 jellybean brings. How will rooting and ota updates coexist? Could use root keeper app.
Using a nas box or plugging a USB hard drive into my router I can set a backup program to auto save all apps and delete/reinstall as needed. The throughput over WiFi to the router storage is much faster than the 5 mbs d/l and 1mbs u/l that my isp has capped me to. I've seen some newer routers that will do 300 mbs depends on tablet tho.
Update: this is turning out harder than I thought, trying file managers for both auto backup options and WiFi transfer. Wonder if a shared folder could automount or be mapped to system. File expert will backup to internal sd but no settings to change directory. Roots looking better all the time.
Some of those 25ยข games were massive, weren't they? I'm down to 5GB at the moment.Last edited by matt; 17 October 2012, 05:01.
nexus root toolkit
Check this out.
Also ota root keeper from play.
You may need to revert to stock or at least relock root to get system updates.
Decided not to root for now. I have plenty of storage...also found out a lot of the preinstalled Google programs can be turned off so they never enter RAM unless you turn them on.Last edited by ZonaMojo; 27 October 2012, 20:23.
There are currently 4020 users online. 1 members and 4019 guests.
