So I am calling this a BETA ROM. Why? Because I am still learning stuff and you all are testers for my improvements. But I have tested the best I can any tweaks I did. I don't release junk but I cannot test everything so I need your help.
Let me tell you, this was a large learning experience! None of the previous All Winner FEX tools, etc worked. The structure has also changed somewhat. Gone are script0, etc... Some things were easier to edit and unpack and some things were not! Example, I could make a new system and it would work but it could not be mounted RW. Took me a while to figure that out. Boot.img changed too! Took me like a day to figure out how to mod it and not boot loop. KK file permissions were a BITCH!
Also I HATE working on devices that don't have ADB over OTG! Why they even left settings for connection to the PC for storage in I do not know. It doesn't work. You cannot even transfer files to internal SD via USB.
Just makes things take longer when you can't do simple things like this.
So, if you find my work worthy, please feel free to donate.
__________________________________
This ROM comes with no instructions or readme. I will work on that as I do more ROMs.
I just did not have the time to write that all up.
So, this means you need to know what your doing and how to use the Phoenix flash tool and drivers. I don't have time right now to write up better instructions.
Get the tools and instructions fro Geekbuying.
Change log:
1) Debloated of junk
2) Proper root which doesn't use install recovery script! You wont loose root this way ever.
3) Updated all Google framework, Play Store, and APPs to latest and this includes superuser and SU binary.
4) Added init.d support properly (not using install recovery script).
5) Adjusted some buffer sizes. Let me know if it helps video playback!
6) Added reboot APP
7) Put in KK AOSP launcher and cleaned it up. I like the icon layout better.
8) Adjusted LCD density to 240 so text, icons and things are not so tiny.
9) Spoofing a Samsung Nexus 10 for better Google App Compatibility. Also adjusted fingerprint for release-keys. The original build.prop is in /system if you want to go back. Just rename using ES File explorer.
10) Did a little theming
____________________________________
Download this and unzip it. You will have a .img file. Use the Phoenix Suite flash tool to flash this.
ROM -> Draco AW80 - Finless 1.0 ROM (317 megs)
Enjoy,
