on android how to see external hard drive plugged into box on windows
i have a mxiii using finless 2.0 and stanes XBMC, on linux i plug in my external hard drive with my movies on it and on windows i can either select map netowrk drive, or just browse to it by network, but on android my box is not shown in windows over networkTags: None
So what you want is to see your android box on windows? like plug your external hard drive on one of the usb 2.0 ports of your android box and be able to see it on your windows? if so then that is my exact setup.
I use an app that basically has many different server services that one can setup, i use "SMB Native Server" (SAMBA) setup on that app so my 3tb HDD can be seen on my Windows PC's, then i map that Drive on Windows so i can access the hard drive faster and easier.
I can also see the internal sd and external sdcard of my android box on Windows that way.
You will also need to setup a statip IP address on your android box.
The android app i use is called Servers Ultimate: https://play.google.com/store/apps/d...ultimate&hl=en
I haven't found a way to do it with a script natively or using other apps, Servers Ultimate is what worked for me and is what i currently use.
Originally posted by leo5111 View Posti never messed with trying to make a static ip so how do i do that on smiling bobs rom? and xbmc? thanks for the help
If using Wifi then go to Wifi intead of Ethernet, once there click on the "3 dot icon" at the top right of the screen and select "Advanced" >> IP address
Originally posted by leo5111 View Postok i found mbox settings and im at configure ethernet device but what do i put for ip,dns,gateway?
For example if it looks like 192.168.0.xxx (where "x" is a number up to 3 digits) e.g: 192.168.0.102 then you put 192.168.0.110 where it says "IP".
Where it says Subnet you put 255.255.255.0, under DNS put your router's IP or you can put Google DNS: 8.8.8.8, finally under Gateway you must put your router's IP e.g: 192.168.0.1 (following the example above).
Note that it can be 192.168.x.x , my network setup is 192.168.2.x for security purposes.
The most common by default depending of the router are: 192.168.0.x or 192.168.1.x
Originally posted by leo5111 View Posthmm im trying to figure out what to put for my ip, i know about some stuff but i know NOTHING about networking
But you can simply put a higher number for your android box. If you DHCP addresses provided by your router start from 192.168.1.100 (most common) then use 192.168.1.110 and up for static ip addresses or even higher 192.168.1.120 and up. Doesn't matter really, just pick one.
Originally posted by leo5111 View Postok i think i got it it let me save the settings now what? i installed servers ultimate but havent set anything up because i dont know how
Originally posted by leo5111 View Postok i can see my sd card how do i set a path to my external hard drive?
There are currently 2829 users online. 3 members and 2826 guests.
