Cube TALK 9X U65GT only bootmenue after trying to install Custom rom
    Good morning to all.
    First I thaught I will register at forum to say Thank You to Lepi, but I did a mistake. So my first post has to be: MAYDAY!!
    @Lepi: This is not a criticism. You did a lot of wunderfull work. This is an cry for help.
    Please let me tell the story.
    I rooted my U65GT, enabled USB-Debugging and activated options for developer.
    This works.
    Then I tryed to install U65GT_V1.8.5W_141110_en_mod Lepi.
    Always it says: installation aborded.
    So I thaught I need special TWRP from Lepi. I downloaded TWRP_2810_LEPI_light.zip later TWRP_2810_LEPI_scrsht.zip.
    Booting into recovery. Install zip from sdcard. I went to TWRT above. Android always says: installation aborded.
    Trying with TWRP-Manager: nothing happens.
    Then I remembered how to install custom rom at my Xperia Neo V. I opened zip an copyed recovering.img to sdcard. Using TWRP-Manager I installed recovering.img.
    Now my U65GT boots.
    Thats all.
    On screen there are only colorful chinese signs. After about 10 minutes later I pressed ON/OFF to stop.
    When I turn it on and I quick press Vol+ I got bootmenue.
    Choosing "recovery" I got right recoverymenue. SDcard is absolutely empty, everything has gone including all my backups like Stockrom, data. (missing data not a problem)
    I can also choose external sdcard. Here I tred to intall zip U65GT_V1.8.5W_141110_en_mod Lepi. And again: installation aborded.
    Is there anyone who can help me?
    Thank you in advance
    Best greetings
    Paul-Werner
    Sorry about my englisch - it is not my native language.
    Sony Xperia Neo V - Superjellybean
    Cube TALK 9X U65GT - big problem
    P.S. My Laptop runs with Debian; there is only a virtual machine with Win XP.
    I tryed just do attach U65GT with adb and fastboot on Debian.
    I am glad, I got connecton.
    But now I*m on end of my knowledge
    Greetings
    Paul-Werner
      The only way I know to resolve this would be to flash a ROM from windows.
      900Supersport
      freaktab developer
        A very good morning.
        Windows? - I feared that.
        O.K. Last night I asked a friend. He agreed me to use his PC with Windows 7.
        What I have to do?
        Did you mean as you described at
        "900SS_v1.0_U65GT_V1.6 20140620 Installation Instructions"
        Best greetings
        Paul-Werner
          Yes power off the tab then connect to the PC and setup the drivers. This is the most awkward part, try searching YouTube for videos, this one for example.
          How To Flash ROM for Every China Phone with the S…: http://youtu.be/ztI8sc8MUNo
          900Supersport
          freaktab developer
            MAYDAY.
            Meanwhile it seems my Cube has a bootloop. But there ist nothing on screen.
            Using charger screen pulses a litte bit lighter than black.
            Plug in USB. PC gives signal "Ping" USB-connection, "Ping" connection lost. Between pings are about 1 second.
            Driver ist installed.
            Pushing powerbutton - nothing happens.
            Same pushing Vol+, or Vol+ and power.
            Please help
            Paul-Werner
            P.S. where can I get a scatterfile?
            I do not habe any acces to Cube.
            Or can I use scatterfile in Brians zip?
              New information:
              If I let ir bee, it seems battery is down.
              Connect via USB an press Vol+ bootmenue displays about 1/2 second.
              No reaction when pressing any key - if I am fast enough.
                First leave the cube on charge overnight. Follow the instructions in the video to install the drivers. Now flash as per instructions. The scatter file is included with my ROM.
                900Supersport
                freaktab developer
                  Sorry about answering so late. I am living on countryside with a very very bad connetcion.
                  And not to something total different:
                  it works! It works! It Works! IT Works! IT WORKS!
                  Thank you very very much.
                  Please enjoy a nice teatime.
                  Paul-Werner
