Samsung TV not recognizing R28 via HMDI- SOLVED
Hello. I was sent here by a guy over at xda. He thought I may find some help over here. I just received the R28 I purchased from Geekbuying.com. I am having issues with my Samsung Smart TV (model un7250) not recognizing the R28 meta. I have tried all of the HDMI ports, and none of them recognize it. I get a black screen and the TV says there is no source. These ports are confirmed working with other devices. I also have a Toshiba TV, which is able to recognize the R28 no problems. Does anyone know why the Samsung TV isn't able to recognize the R28? Very fruterating as I want it on the Samsung and not the Toshiba. I was informed on xda that this is a beta versionot which I didn't realize when I purchased it. Thanks!Tags: None
I reported these problems with RK3288 devices time ago.
Fixed now for ZERO Devices Z5C (check page 19) but I also found a similar problem with Beelink R89 (same motherboard than your R28).
Also this device sometimes can not remember the configuration. I don't know the specifications from your TV, but you can try as follow:
- Place both TVs in the same place
- Connect the box to the one is working well (Toshiba)
- Navigate to Settings > Display > HDMI Mode
- Choose 1080p-60Hz (if supported by this TV), make a change
- Without powering off (the box) unplug the HDMI from the TV and plug in in to Samsung TV
- Hope, it's working now, navigate to Settings > Display > HDMI Mode and choose the best configuration for you
Let me know if ok. Netxeon's hardware engineer told me will come to our office this week and check this problem with our Samsung UHD TV. Some RK3288 already fixed this problem.Android TV Box direct from China. English & Español
I can't find un7250 but I can find HU7250 (UN..HU7250.... http://www.samsung.com/us/video/tvs/UN65HU7250FXZA).
I find out HDMI 2.0 .
- Do you also try to use another HDMI cable (not the stock one)?
- I also read about DTS, is it able to disable it at the TV (because at the moment there are some problems with path-through)?
- Try to disable every picture post processing futures at the TV???RK3288 Devices
- Overview BOX (LINK !)
Last but not least be sure to be at the latest FW (110k4)...RK3288 Devices
I also did not find info about that TV, but it is probably a hardware and software problem there with the 4K detection.Android TV Box direct from China. English & Español
Maybe a solution which I found at another forum and seens to be more the TV than the box:
I was able to get it to work with the Samsung UN50HU6950. It initially didn't, but it worked once I toggled the UHD color inside the TV options menuRK3288 Devices
Originally posted by Javimetal View PostI reported these problems with RK3288 devices time ago.
Let me know if ok. Netxeon's hardware engineer told me will come to our office this week and check this problem with our Samsung UHD TV. Some RK3288 already fixed this problem.I found the solution to my problem in a different forum that doesn't involve having to move TVs around. In setting Picture > Picture Options > HDMI UHD Color > Slect whatever HDMI port your box is using > Follow onscreen instructions. Done!
Originally posted by htcuser8740 View PostThis worked! Thank you so much. Nothing like unhooking a 60 some pound Toshiba and lugging it around.I found the solution to my problem in a different forum that doesn't involve having to move TVs around. In setting Picture > Picture Options > HDMI UHD Color > Slect whatever HDMI port your box is using > Follow onscreen instructions. Done!
The problem anyway is from the box, not from the TV. That is why some factories are working on it yet, and anothers already fixed this.Android TV Box direct from China. English & Español
Originally posted by krzmtl View Posthas anyone found a solution for this?
i cant get the samsung curve to recogize my s82 netxeon
was curious if a hdmi 2.0 wire would help.
i cant seem to get the tv to change the uhd color setting...
but no go
help
i have 2 4k tv's that's itRK3288 Devices
but no go
help
I think (did not try final firmware yet) in RK3288 case, Netxeon could fix parcially the problem by changing some resistors on the board (they came to my office to do it while testing my 4K TV) and some other software modifications. I don't know if this problem is total fixed.
Anyway, you can contact Oman here in the forum, he is their software engineer...Android TV Box direct from China. English & Español
There are currently 1538 users online. 0 members and 1538 guests.
