3A Power Supply for an M8
    Does anyone use a 3A Power Supply? I have been researching and have found that the supplied 2A PSU may be causing some issues.
    Also, what size plug do I need to look for?
    The 2A PSU definitely causes issues on all TV Boxes.
    3A is enough for external harddrive and 3D games & 4K videos.
      Would this be right?
      http://www.****.co.uk/itm/UK-Plug-DC...-/251698018215
        It looks right to me.
          Be aware of the length of the connector and the Diameter of the Centre hole/pin
          These china boxes can use a deeper socket and the centre pin can be thinner
          One power pack would drop out as the barrel was to small length wise would not seat properly.
          Yes a 3 amp plug pack does/can help.
          And that one on **** looks Good as mentioned.
          Cheers
            Cheers
            Thanks for the heads up. The plug appears to be 5.5mm x 2.5mm, but may be 5.5mm x 2.1mm. Either way this one should fit....http://www.****.co.uk/itm/UK-Plug-DC...-/251698018215
