lates ffmpeg and x264 library
only you need compile your dvb modules
latest tvheadend source that I compiled.
support dvb-t/t2/s/s2 and straming tv channel
It supports the following inputs:
DVB-C
DVB-T(2)
DVB-S(2)
ATSC
IPTV
UDP
HTTP
if your rom support init.d no need this
1-copy data/dvb folder to data/dvb
2-copy init.d folder to system/etc/init.d
3- copy system/lib to system/lib
later open terminal copy paste
mkdir /data/data/.hts
mkdir /dev/dvb/adapter0
ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0
ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0
ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0
ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0.ts
mkdir /dev/dvb/adapter1
ln -s /dev/dvb1.frontend0 /dev/dvb/adapter1/frontend0
ln -s /dev/dvb1.demux0 /dev/dvb/adapter1/demux0
ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0
ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0.ts
chmod 777 /data/data/.hts
chmod 777 /dev/dvb*
/data/dvb/tvheadend -C -c /data/data/.hts
open explorer write 127.0.0.1:8891
if it work you platform on alwinner. you add your dvb modules. I dont know How compile allwinner.
http://www62.zippyshare.com/v/59826374/file.html
wait your feed back
