Prahjister MK908II 4.2 1080
    Took the stock rom. Removed all the crap apps. update all the apps except 2. KK launcher. As soon as you update the 2 apps KK launcher will work. Which allows the OK Google feature if you have a mic attached. Init.d. Patched to 1080. Vsync fix applied. 5gig of app space. Recommend SPMC for perfect 1080 playback. You can get it in the play store
    Flash with rkbatch tool.
    I'm quite happy with vectorlinux/Magnus33 rom, so I don't know if I'll install this rom, anyway, it's very pleasant to have more new choices.
    Are you using d33 kernels?
    Thanks for the work!
      no just stock patched
        Originally posted by prahjister View Post
        Took the stock rom. ....
        Did you base your ROM of the latest Tronsmart firmware from 2014/07/25 ?
        Thanks!
          Originally posted by mowgli View Post
          Thanks!
          Yes that is correct.
            Great! Thanks!
              Great! Thanks!
              I gotta ask....why did you ask that?
                Because I tested it a week ago to make sure that Netflix works without video/audio sync issues.
                All current KitKat ROMs have this issue on my mk908ii.
                  Its 720 but I took the beta stock kitkkat that wouldnt boot and i only tested for a minuteI don't remember any out of sync issues. it's in the CX 919ii. if you can help me find a Kit Kat kernel that has been patched 1080 I can probably patch that one to 1080
                    Thank you very much for willing to help !
                    As I wrote before I tried almost all compatible KitKat ROMs. Here one of them http://www.freaktab.com/showthread.p...l=1#post203911
                    The strange thing is that no one else experience the same issue with their mk908ii. Probably mine has something different. I bought it two months ago from geekbuying.
                    Once again, thank you!
                      Im new to the 3188 scene. I found the general area to change to 1080 in the kernel but it will take me a while to do it. I have never worked with a disassembler before. Just have to figure out the bytes to change.
                      Did you try that KK rom i cleaned up?
                        Which one ? I thought that the ROM in this thread is 4.2 not KitKat.
                          look in the cx919ii
                            look in the cx919ii
                            Is this the one you're talking about ?
                              http://www.freaktab.com/showthread.p...oot-Cleaned-up
                              Yes sorry with the slow reply....i worked in the lab all day today at work...
