Different RK3288 Device Benchmarks
    Results from androbench:
    100MB Read, 50MB Write in Settings for more accurate score(For HPH)
    HPH RK3288/ r89 / firetv / Draco AW80/ Q8 RK3288
    seq. read MB/s
    46.4 / 35,84 / 81,63 / 29.45 / 19.64
    seq. write MB/s
    13.75 / 10,12 / 13,41 / 6.38 / 6.78
    random read MB/s
    9.17 / 5,51 / 10,82 / 7.62 / 3.62
    Random write MB/s
    1.45 / 0,23 / 0,82 / 0.25 / 0.2
    sql insert TPS (Transactions per second)
    131.86 / 33,65 / 98,0 / 26.31 / 27.13
    sql update TPS (Transactions per second)
    158.98 / 37,71 / 103,34 / 31.71 / 29.84
    sql delete (Transactions per second)
    158.98 / 37,84 / 105,44 / 31.59 / 34.96
    browser (msec) (Lower is better)
    79.75 / 345,5 / 119,0 / 290.75 / 542
    Maybe people can do new benchmarks with latest firmware for their devices and also wifi/ethernet performance.
    Thanks to bloodgnome that did the tests, I added the HPH ones.
    Think bloodgnome's test were done on default settings, maybe redo tests with bigger read/write test file for more accurate results in androbench. The default 32MB read and 2MB write files in settings is less than a second, so not accurate.
    It looks like HPH RK3288 EMMC is twice as fast as Q8 RK3288(Cheaper & slower EMMC).
    UBOX 8GB
    FW: 110K4
    Androbench v3.5 (standard settings)
    Code:
    Sequential Read   34.01 MB/s
    Sequential Write   8.79 MB/s
    Random Read        6.12 MB/s, 1568.01 IOPS(4K)
    Random Write       0.22 MB/s,   57.73 IOPS(4K)
    SQLite Insert      31.26 TPS, 9.59 sec
    SQLite Update      35.41 TPS, 8.47 sec
    SQLite Delete      35.16 TPS, 8.52 sec
    Browser            424.0 msec
    Market             320.5 msec
    Camera             465.75 msec
    Camcorder         1010.0 msec
    Because I block the internet by using a wrong Gateway/DNS-address at static IP I have no idea how it determine Browser & Market and also the same for the not existing Camera & Camcorder ????
    A1 SD Bench v2.2.0 (standard settings)
    Code:
    (!) Cached Read (This usually happens when: ...plenty of free RAM or SD Card is very slow, or 'advanced tests' are not set...)
    SD Card  (free ~4GB)
      Read  148.69 MB/s
      Write   7.25 MB/s
    RAM
      Copy 2031.64 MB/s
    A1 SD Bench v2.2.0 ([Advanced benchmarking] checked at [Settings])
    Code:
    SD Card  (Quick)
      Read  591.57 MB/s
      Write  14.75 MB/s
    SD Card  (Longer)
      Read  731.66 MB/s
      Write   7.16 MB/s
    SD Card  (Random I/O - with reboot)
      Read   31.29 MB/s
      Write   2.13 MB/s
    SD Card  (Accurate - with reboot)
      Read   40.68 MB/s
      Write  15.13 MB/s
    RK3288 Devices
    - Overview BOX (LINK !)
      Ok. I will redo the tests with a bigger read write files and also test a kr42 i still have lying somewhere around here
