Copy MK808B firmware from one device to another
It would probably be easier to find a copy of the firmware you have one your other device.
Go to the about device settings section and copy the kernel version information and do a search for it exactly, you'll get a result.
Example:
Then do a search for the information under Build number: mk808b_v401j2
Example: http://bit.ly/1uDK3yqCurrently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Originally posted by Mtfcgary View PostHi all. I updated my Mk808B firmware and it doesn't work correctly. I have another MK808B which is identical is there a way to copy from one to the other
There are currently 2602 users online. 0 members and 2602 guests.
