Universal USB HOST DVB-T/T2 Android Tuner
    Does it can work on Android Smart TV boxes?????
    Free 100Gb space for your files:
    https://degoo.com/g/Ov7nAz0
    I don't know... normally you need TVHeadEnd kernel/modules support at Android to support USB devices like this... but I can't find any TVHeadEnd information for this device, so maybe yes or maybe no ???
    They only talk about 'Android 4.2 or above' and I can't find any tools or drivers at the [Download] section and also find no needful information if I search for 'PT360 xbmc'...
    But if I search for 'Geniatech PT360' I found it at aliexpress (383 orders) and the first feedback I read is "... Works only on some device" ...
    RK3288 Devices
    - Overview BOX (LINK !)
      Here you can find CPU compatibility list.
      It have micro usb port,but our smart boxes do not have micro usb host.Can we to use some Usb adapter?
      If it can work on tablets i think it can works on Android Smart Boxes.
      and this:
      Observation: Tv tuner Pad may not be compatible with all A23 tablets now.
      Pad TV tuner may not be compatible Samsung Galaxy: Note / S II / now.
      The above is for reference only and not totally confirmed.
      Requires an Android device with a 1GHz or faster dual - core CPU functionality and USB host mode
      Android 4.1 or later
      Playback of MPEG - 4 / H.264 video requires a processor with NEON support (eg Tegra3).
