Help with resolution video Beelink m8
Is the picture (output) to small?
E.g. at my TV I can disable overscan so I have to scale the output at the box at 100%
You can find it somewhere at settings at display or so on...RK3288 Devices
- Overview BOX (LINK !)
try installing finless bob 2.0 for tronsmart s89 http://www.freaktab.com/showthread.p...inless-2-0-ROM then install this http://www.freaktab.com/showthread.p...-s802-platform
download finless 2.0 extract it throw contents on sd card formatted fat 32... 1) Copy all the files from this ZIP onto the SDcard you should have:
factory_update_param.aml
s82_s89_finless20.zip
recovery.img
README FIRST.TXT does not have to be copied.
2) Power off the S82/89 and unplug power.
3) Plug power back in, Make sure it doesnt boot!
4) Using a tooth pick go in and press and hold the reset button.
You know you have pressed it if you feel the click.
5) While holding the reset button down, press the power button and keep holding the reset button!
6) While holding the reset button, wait until you see the logo and you can then release the reset button.
7) The ROM should auto install and reboot when done.
There are currently 1380 users online. 1 members and 1379 guests.
