how do i increase internal memory from 1 to 6 or 8 gb
    hi, now i use U51GT C8 same this site
    http://cngadget.info/2014/11/11/cube-talk-7x-octa-review-a-powerful-80-dual-sim-3g-phablet/
    octa core and mali-450MP4 of mt8392 is OK
    Antutu much more than 31k
    it fast for all my applications and stability,
    GPS is great, monitor display is beautiful
    but now it have some problem
    now i can not add applications
    because internal memory is full... T_T!
    internal memory of default is 1 Gb only
    How do i solve or
    how do i merge internal memory to 8GB
    (all memory is 8 GB)
    thank you very much.
    ^_^!
    epic benchmark=62.2 fps
      yea, i'm with the same problem of space
        Solution to increase internal storage space in CUBE talk7x U51GT-C8
        Hi friends, I have the same tablet , actually 2 (my kids) and I had the same problem and now I have a solution, please check my video I show you there how to do it..
          Hi
          use this soft to repartitionate the internal memory (for MTK devices only, you will need the MBR files of the ROM installed in your tablet)
          Backup your tablet. Then reflash the 2 new MBR file and wipe data in CWM.
          You can find here already created MBR for 6 Gb of internal /data (instead of 4) for the Cube Talk 9X only: CWM zip for 6 Gig apps space
          Note that when you increase the /data size, it decreases the size of the internal SD.
          If you have a model with a small capacity, my advice is to install a 32 or 64 Gb external SD, and to permute it with the internal one.
          See here how to do it for Android KitKAt (it should be the same for all Kitkat devices, but do it with your own files from the ROM you flashed your tablet with):
          Before doing the flash of the new boot.img file, copy the entire content of the internal SD to the new SD with an app on the table (not via usb) like ES Explorer in order to keep the file permissions. After the flash, you can format the old internal SD which is seen now as the external.
            Where is patch 4 GB app space ???
              Hi, I haven't done 4gb "patch", but I sure did a 3gb "patch". If you know what you are doing and have the CUBE TALK7X U51GT-C8 (octacore) you can try this EBR's.
              My Custom EBR's for Cube Talk7x U51GT-C8
              and if you have doubts about how to install these EBRs and expand your cube's internal space please check my video I explained the procedure, links for tools etc and also read the video's description
              Video Guide to increase Cube Talk7x U51GT-C8 internal space
                Many thanks ... But I have installed the new ROM, for next time and try this ...
                  You're welcome... and well I hope you try it someday ... by the way does your new rom has more space for internal memory?
                    Hello again, and installed the new rom Lepi 2.0.5 B ... And I installed a patch of 6 gigs was in the forum ...
                      hi, now my CUBE talk 7x octa... Rom is 3+3 GB
                      your files is very work..!!
                      thank you very much
                      ^_^
                      _/\_
                        thank you very much
                        ^_^
                        _/\_
                        Hello,
                        YOU are welcome!!! I am happy to help . Enjoy your CUBE!!!
                          editing my EBR files did it fo me
                            Hi pals, got a doubt,
                            Did this process works on the quad core version of this tablet (U51GT-c4b)
                            thanxs
                              thanxs
                              yes.. but you need to get the ebrs for your tablet. and someone to modify them
