Help with XBMC and samba
Hi guys. I need help. I just bought a Q7 android box and I'm loving it, the only problem that I have is to set up samba with Wi-Fi. I tried with the Ethernet cable and it works like a charm, but with Wi-Fi it doesn't even tries to search. I already tried to mix around with the smb.conf but with no luck... What can I do to solve it? Also, should I use the official XBMC app or other un official XBMC?Tags: None
I'd try this app - https://play.google.com/store/apps/d...samba&hl=en_GB
It only works on WiFi, not ethernet, but as that is the opposite of your current issue...
There are currently 2174 users online. 0 members and 2174 guests.
