[SOLVED] - Please, tips about unbrick CS968?
The drivers are not the problem. RKtool detected the device.
Make sure you have an original ug802 and try then the finless 1.8beta ROM here http://freaktab.com/forum/tv-player-...1-8-custom-rom
and not by example an ug802b. That is a later generation or any clones of the ug802.
Okay have fun.
JD
Big thank you to JDefense. i've used that link : http://chinagadgetsreviews.blogspot....p-rockusb.html , and my device is unbriked. Now i would ask you what rom for play iptv on this box . thanks .You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
I am having this exact same issue.
I have followed this guide exactly. I pull the plug while it says "Wait For Loader Start" and re-insert and I keep getting "Wait For Loader Fail".
I have a RK3229 1g/8g Nexsmart D32 attempting to install stock firmware from manufacturer's website.
I am using AndroidTool and RKBatchTool all versions.
Same result every time.
Any help here would be greatly appreciated.
try AndroidTool 2.38 , maybe your Loader is bricked ??? i have the same with my UT3 ,
good luck / gefattern
There are currently 2207 users online. 0 members and 2207 guests.
