MK-888 Usb Debuggin mode problem
    Hey guys.
    I got an MK-888.
    I am trying to root the device, but I just can't select USB Debugging mode.
    I go to developer options, and check the box for usb debugging.
    Then whenever i do another selection, or close and re-open settings, the USB Debugging is unchecked.
    Any idea on how to fix that? It's driving me crazy. I am trying to root for 2 hours now and I just can't do it!
    Sounds bad, seems so they disabled it...
    What will happen, if you switch at [USB] the [Connect to PC]?
    RK3288 Devices
    - Overview BOX (LINK !)
      Nothing... It just won't work and I can't get to root it... I did a reset from the settings menu, so it erased everything and went back to factory settings, and I still have the same problem.
      I want to root it.. any recommendations?
        No, sorry, I also only know these 3 settings http://www.freaktab.com/showthread.php?7369-Same-device-other-name-(AC8350-BX09)&p=105216&viewfull=1#post105216
        And every rooting tool I know which works at this device I think only works via sidelode (ADB) ... maybe https://towelroot.com/ but I don't think it works at this device, but you can try it...
        RK3288 Devices
