Best "out of the box" ready user-friendly Tv Stick?
    My uses would be pretty light and basic. Facebook, Twitter, Web viewing, Netflix and Youtube videos.
    Is there a stick at this time that comes pretty much out of the box with strong wifi without having to do any mods, rom flashes, or any of that stuff. I think i'd be ok with simple updates where I just click the 'update button'.
    also Less than $100 in cost?
    bump.
    It just seems that every android device has an issue that needs to be corrected by flashing an independent rom to fix it.
    so to reiterate are there any devices that are pretty much issue free from the start. Especially with netflix and youtube videos being in sync. Great wifi reception?
      hmmm, plug&play is difficult with "Chinese" devices... because you focused also at netflix, because of HD 1080P, I think you should have a look at
      amazon fire tv (aftv)
      which is at best case with the correct fw rootable (but not really need, because you can 'sideload' apps (also XBMC) without root; you need root e.g. if you want to use USB-HDD and want to keep the actual fw-version) but you have to find out, what's about cams because of skype....
      (and maybe also at Chromcast http://www.theverge.com/2013/7/24/45...aming-tv-stick )
      RK3288 Devices
      - Overview BOX (LINK !)
