MXIII 109K4 NTSC Analog Video Support?
I've been trying to set up one of my MXIII boxes on an old analog TV with the yellow video input only. I am getting a black and white screen with the image constantly scrolling and fuzzy. I presume the default analog output is in PAL and not NTSC. Is there any way to adjust or add the 576i resolution to the box?Tags: None
Originally posted by hybrid_r View PostI've been trying to set up one of my MXIII boxes on an old analog TV with the yellow video input only. I am getting a black and white screen with the image constantly scrolling and fuzzy. I presume the default analog output is in PAL and not NTSC. Is there any way to adjust or add the 576i resolution to the box?
Goto settings --> Display --> output mode from top of my head and select the resolution also take it off auto detect.Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View PostYes sounds very like much a ntsc /pal issue.
Originally posted by hybrid_r View PostThanks for the speedy response. Didn't see the resolution the first time. I'll try that again.
auto, pal, ntsc etc settings, I know some tv's conflict and you need to set it manually , ntsc, secam etcBugs are Sons of Glitches!
JustMe
Actually if you want to change resolutions... You'll need to turn the "Auto Detect" off.
At least this is what I find when I'm coming into this Box (1G/8G AP6181) MXIII for the first time, after a Factory Reset, or a Firmware Update. With the Auto Detect set to "On" the Box defaults to the PAL 576i Mode.
However I'm clearly trying to use an HDMI Cable with a TV Panel that does 1366x768 (e.g. 720p).
The only way to "force it" into said "Mode" e.g. 720p@50Hz is to do so manually.
Given that the Internet knows no Borders.... FYI:
480i@60Hz = ATSC / NTSC
576i@50Hz = PAL
The rest or just the different HD Modes which should otherwise be pretty universal sans the Frequency that your Panel / TV / Projector is capable of reproducing. (e.g. Trying to watch a 60Hz Source on a 50Hz Monitor is going to be very jerky to say the least.
There are currently 1677 users online. 1 members and 1676 guests.
