ug802 Finless 1.5B -- BETA TEST ROM
    OK guys I am trying to work on the audio/video sync issues. It's a guessing game since my development is on a PC and I am using a monitor with HDMI but no audio from HDMI. Sucks I know but I am putting into this my best knowledge about how android works to try and fix these issues.
    YES we do want GPU video decoding! But can we get it? We shall see.....
    This BETA ROM is for POWER users only. I will NOT be making a BETA update.img package. You must use my Flash tool and have the drivers etc ready to go. If we fix this issue then YES I will make a update.img package as a final ROM.
    PLEASE READ the README in the package and what I ask you to do to flash this. Basically YES I need you to erase IDB this go around. I also need the new 1.16 loader flashed! THIS IS WHY we must use the flash tool.
    I do not provide instructions for installing the drivers and flashing. Again power users here. I expect you are already setup to use the PC flash tool. If your not, then read the README from my 1.4 ug802 ROM.
    So here is a 1.5 BETA. What I did was use LIB files and other files from a great performing ROM to see if we can solve the audio/video sync issues. It is rooted and does have init.d support built in. Thats about it! No other patches like China Mobile google play etc! We are focusing on the audio/video sync issues nothing more here. Later I will refine it IF we fix it
    Understand, as we test and continue to develop and work on this, I will be supplying new system.img packages. You wont need to erase NAND again (unless I ask you to) if I update system.img. So as I release these updates, please be prepared to do this properly. I will provide exact instructions.
    Download the BETA ROM here:
    ROM -> ug802 Finless 1.5 ROM BETA TEST of audio/video sync (167 megs)
    Let me know!
    OH and please... can we keep replies here focused on the BETA TEST please. NO QUESTIONS about should I or shouldnt I flash kind of thing. Again I am looking for POWER users here. If you think you are one, feel free.
    Also I will be up most the night and I am off tomorrow so as you provide input I will work on stuff QUICKLY in the next 48 hours!
    Finally please do me a favor! DON'T use the ug802 stock launcher (launcherNEW)! Use the standard ICS launcher (launcher not launcherNEW). I beleive that the ug802 "petrified" launcher is a resource hog and a possible reason for performance issues.
      Thanks for all your hard work.
        you've shorten my night! will give it a go before bedtime... ;-) thx i.a.
        alex
        ok, what i just noticed. flash streamig seems still out of sync, but i just started a bluray image with emediacenter and this one wasnt out of sync - of course it had to buffer every now and than cause of wifi, but audio/video sync was fine. will cross check tomorrow with 1.4 again, if it is a step into right direction or if i missed this one in v1.4 and it already worked there!? bedtime now ;-) will check sound(quality) tomorrow too.
        btw wifi connection is 150Mbps now for me!!!!! :-O
          I tried it out - I think youtube sync seems a bit better, but definitely not quite right. Divx played on default android video player still out of sync... again, possibly slightly better.
          The mk808 jelly bean rom someone posted on here is really good, apart from the screen ratio being wrong (1024x768 or something like that showing in antutu) and the wifi not working. It might be worth working from that?
            The MK808 jellybean ROM is mine. But let me ask. Are there still video/audio sync issues with that? I have to tell you NO WAY will I ever get Wifi working on that MK808 ROM for the ug802. I wont go into why but it is a kernel compile issue. BUT again did it have video sync issues?
              Yes... I do believe I have a set of drivers and wifi modules that work WAY better than stock! Those are keepers for the final ROM
                I watched a whole xvid movie and it seemed great to me.
                In fact, I've just re-flashed it and watching a youtube video again from the app (I have an ethernet adapter) and sync is perfect in my eyes.
                  THAT is good news! THAT is what I wanted to hear
                  We need more people to input though.... I may cook a really wierd system.img to find the best base to work from, but if this fixes it, maybe I do not have to do that.
                    I remembered it was the ROM from the following link: http://www.armtvtech.com/armtvtechfo....php?f=13&t=53
                    mk808_rooted_JB_update.rar
                      very confused rom 1,5
                      iam runing the 1.4 rom
                      little confused as i run the 1.4 rom and the video sync is perfect
                      i use bs player mx player and xbmc non neon and the sync from live streaming and tuxbox via xmbc perfect only problem i can sort is the usb ethernet only will connect at 10 meg so using a local ap and N and getting about 71 meg thou put
                      would be nice if they was a way to manuel set the ethernet to 100
                      thats all i find wrong with rom
                      Let me know!
                      Please consider donating to purchase hardware for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
                      Please Click the Donate Button
                      PS
                      If you are having trouble with the above link when using Tapatalk than here is the email link for donations below
                      https://www.paypal.com/cgi-bin/websc...=ZYCM4NZ4J6F3G
                      Thank You
                        little confused as i run this rom and the video sync is perfect
                          ps to my last thread
                          dont know if the reason my runs perfect but i set my min cpu speed to 1ghz
                            Well I was going to stay up many hours tonight but it appears the largest customer base for interested users is 1/2 the world around!
                            I am calling it a night.
                            But I will be home all day tomorrow so I will respond to TESTING feedback first thing in the AM.
                            I am looking for good news but I expect to work more at this as I know we are NOT there yet, but I think I am getting closer!
                              My experiences so far:
                              Mx player without audio s/w decoding enabled: stuttering audio&video
                              Mx player (9GB mkv through smb) with audo s/w decoding enabled: flawless
                              XBMC: flawless (HD not yet of course, due to lacking h/w acceleration...)
                              Youtube app: audio lags a little bit behind, sometimes skips audio-parts (to catch up ?)
                              Other experiences (may not be the main goal of this beta)
                              I have a fly mouse which worked perfectly with 1.4 but with 1.5 the layout is screwed up (for example the "z" and "y" keys are swapped; back button doesn't work)
                              @robgee65
                              Could you elaborate on why you are using XBMC no-neon ? I use neon and couldn't really figure out if ug802 is a neon device, but I see no real difference in performance between neon or no neon
