Tayun -s802
    Tayun -s802
    Hi m8s what do you think about this device? http://www.lightinthebox.com/sv/tayu..._p2087851.html
    Is this more detailed to get respons?My wonder is if i can use rom for tronsmart elite??
      omg way too expensive my friend especially for a 2.4ghz only box. although the outside casing looks nice.
      Bugs are Sons of Glitches!
      JustMe
        hi m8s here are some more info about my s802,hope some one can find out if i can use Finless rom (Amlogic s802)for this device?
        regards
        Last edited by belmando; 16 December 2014, 19:17. Reason: could not attached the pictures
          regards
          I have the same device.Iwant to try codesnake openelec version it says it fits k200 board which is m8.
          Could you try and give feedback ? http://www.freaktab.com/showthread.p...110-MX2-G18%29
            hi m8s
            My box does not have any recovery button in the AV hole!!i am not sure if i want to test it,i need to do som search!
            regards
              hi m8s
              regards
              I noticed a hole in the back but no button i could see.
              ill try with a paperclip
                Hi m8
                if you open the box by removing plastic cover at on every corner you can unscrew 4 screws than slightly peel it out the board.It has four samsung ram and there is a little button look likes a recovery button but it does not sits correctly to the case hole!!you can try when the board is not in the case!!
                if its the correct board to install openelec a bigger hole could be drill to access that fcuking button
                regards
                  Hi m8
                  i can not go further whit this .Cause when opened the box recovery button fell off from PCB.Its another junk i managed to buy.First one was a tronsmart r28 pro that it worked perfect a couple of hours then it was kaput!!
                  the only option left for me is to try flash it via sd card .will try to root and put finless Rom on it.openelec for wait for a while
                  regards
                    Hi m8
                    regards
                    Thanks a lot.
                    looking forward for your results.
                    if its no possible im shipping thia back to China
                      Thanks a lot.
                      Hi m8
                      the best thing is to send it back and purchase another one that has wide support at here freaktab!!
                      regards
                        hi m8s
                        since my recovery button does not exists anymore and sd card reader is faulty : how i am supposed to flash a rom on my device ?is there any app that puts amlogic s802 in recovery mode via on screen menu?
                        regards
                          Thats expensive
                          Cheaper on geekbuying
                            hi m8
                            No more purchase from Geekbuying!!
