Porting Jellybean to the PMID700
    Is it possible?
    I have seen converters for other Roms to convert them to something that would work with the older phone I have (a Samsung Mesmerize) and upgraded my phone to the latest Jellybean ROM (AOKP) that way...
    Is anyone considering doing something like that for the PMID700?
    Originally posted by dmoneh View Post
    Is it possible?
    I'm still working on a custom ROM for my 701C and I don't have any specs on the 700, but I won't say that *someday* I'll see if I can work on it....
    I know, not a very hopeful response, but it's better than nothing :-)
    https://public.bay.livefilestore.com...ion.png?psid=1
      Re: Porting Jellybean to the PMID700
      I would take a look at Cm10. What I did before William worked his magic was look at the Cm10 thread over at Slatedroid, find a tablet comparable to your tablet, and try their compatibility zip. Be warned I'm on an Allwinner A10, which is pretty unbrickable, your system may not be as hardy.
      Sent from my Polaroid 701c tablet running Cm10
