I'm using my Logitech K400 wireless keyboard and most of the time it works fine, however I have noticed a weird bug. When you operate with the keyboard ie. type a website address in the browser and you hit the "Enter" key, the mouse pointer appears and if it's above any buttin it will click it instead. It's like "Enter" key is the shortcut for the mouse-click, so you need to be careful that the mouse pointer is above the item you currently edit. In other words, please differentiate between hitting "Enter" key and mouse click
Also not sure if that's relevant but in some apps ie. games I cannot click on some buttons using the mouse pointer. Not sure if I need any extra app that simulates the touching/tapping but fixing this would also be awesome!
One more time thank you for your hard work!
Cheers!
