There are two method to update the stock firmware for mk808b plus. If you still can boot to android , you can use the sd card flash method, it’s easy and don’t need PC to install. Instruction is here:
step 1: download the latest firmware from our blog.geekbuying.com (just search mk808b plus to find the newest firmware)
step 2: decompress the download file, and copy 3 files(10*k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
step 3; connect your mK808B plus with TV through the hdmi cable in the package, Insert the TF card which contain firmware file to mk808b plus, connect the mini usb cable with OTG port in MK808B PLUS ,and then press the reset button with a small pin on mk808b plus , find the reset button here:
step 4, check your tv screen, it should inform you the update is in progress.
This method don’t need bother you to install the correct pc drivers, if you have windows 8.1 pc or mac or linux pc, and don’t know how to install the driver correctly, then try this method.
Method 2: use amlogic usb burning tool to update the firmware. If you stuck at boot image or you think you totally brick your mk808b plus, you can try the following method:
step 1 download the latest firmware from our blog.geekbuying.com (just search mk808b plus to find the newest firmware)
step 2 download the usb burning tools here:
http://www.mediafire.com/download/jmob9aniob7u9py/amlogic_tools.rar
extract the file: USB_Burning_Tool_v2.0.0.140306_Alpha_x86.rar
and you will get an *.exe file, run it, and follow the instruction,it will help to install the burning tool on your pc.
and in order to make sure you don’t have drivers problem, we suggest you to install this tool in your pc first:
http://www.moborobo.com/
Now run the usb burning tool, you will see this:
Click “file” and choose”import image”, choose the .img file you just download,
Now it’s important step, Make sure your mk808b plus is power off, use the mini usb cable to connect mk808b plus with PC.(use the OTG port in mk808b plus), then use the toothpick to press the reset button(see above photo), and at the same time, connect the mini usb cable with your pc to power on the MK808B PLUS. and then the burning tool will find a new usb device:
and then click start button to flash. It will take 5-8 mins to finish the flash.
Source from: http://bit.ly/120RNBf
