I plugged the cable into a notebook and it was fine no problems. Connect back to the draco and again no ethernet.
Draco Meta Ethernet no longer working
Anyone have a problem with the ethernet. It definately was working at first. Just plugged in the ethernet cable and turned on ethernet in the settings. But now it is not getting a connection and ip address at all.
I plugged the cable into a notebook and it was fine no problems. Connect back to the draco and again no ethernet.Tags: None
Originally posted by freakdave View PostAnyone have a problem with the ethernet. It definately was working at first. Just plugged in the ethernet cable and turned on ethernet in the settings. But now it is not getting a connection and ip address at all.
2. Try a new cat5/6 cable
3. Reflash FW
4. Return box
Originally posted by alwaysbless View Post1. Ensure that DHCP is enabled and it doesnt think you are manually defining settings
3. Reflash FW
4. Return box
Originally posted by freakdave View PostThanks. Think was just my router acting up. Odd. Finally after trying everything I rebooted the router and I now get an ip address.RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostThat's why I never use DHCP but static IP (worst case a mix of both e.g. x.y.z.002 - x.y.z.100 for DHCP and so I can use x.y.z.101 - x.y.z.254 for static IP)...
There are currently 2205 users online. 0 members and 2205 guests.
