Ugoos UT3 - How to connect to PC???
    Good morning my friends
    I am trying to update the firmware on my Ugoos UT3 but i can`t get the device to connect to the PC. Can you provide clear instructions on how to proceed?
    Thank you.
    BTW - Is it possible to update without connecting the device to the PC? By copying the newest firmware to a usb pen and connecting it to a usb port in the Ugoos?
    Hi
    i'm interesting too.
    I have download the firmware i have found on the forum and also the fimware from official ugoos.net web site : ut3_2.0.4
    i would like first to try to official one.
    I have try poweron the box with the recovery "buton" (small hole on the right of the box) pressed, but nothing append, no boot at all.
    regards
      Hi, you can use this guide to update firmware. link
      Tools from guide you can download here
      Official Ugoos firmwares with linux you can find here.
      Official Ugoos firmwares for UT2/UM2 and UT1 you can find here.
      Sorry for my english XD
        hi Ava,
        stupid question maybe, but the UT3 device must be connect to the power or I can just play the usb cable to between my pc on the OTB port of the ut3 device without the ut3 device connected to the power ?
          Cheers Ava
          I`ve already tried that guide, but nothing happens!!!
          The device doesn`t turn on when i connect it to my pc via usb otg cable and no new device appears on my pc when i link both.
          I wonder if this will be the single only freaking way to update the firmware on this device. What a nightmare!!!
          Best regards guys.
            Originally posted by danyway View Post
            hi Ava,
            It`s a very good point danyway, one that i would also like to know.
            Anyone can enlighten us?
              hi Ava,
              1. Disconnect power cable from device
              2. connect device to pc by otg port
              3. press reset button
              4. connect power cable to UT-3
              What operatingsystem are you usingon your PC? if you use Windows 8.1 you need to performadditional steps
              If you have official firmware 2.0.3 version and up you can try this:
              1. Connect Ut-3 to PC by otg
              2. Load android
              3. Open power menu
              4. R
              eboot bootloader by long press on "Reboot recovery"
                My OS is Windows 7 Ultimate 64bits.
                My Ugoos firmware is 1.0.9
                  Hello Ava
                  First the good news. Your method definitely works for sure. I`ve updated my firmware to 2.0.4 without problems, so well done.
                  But the bad news is that with this firmware the device seems to have lost root.
                  So how can i unroot it again?
                    Originally posted by fernslb View Post
                    ... So how can i unroot it again?
                    I think you mean root => http://www.freaktab.com/showthread.p...471#post253471
                    RK3288 Devices
                    - Overview BOX (LINK !)
                      I had Windows 8.1
                      Thank you ADA, I was able to update my box to firmware 2.0.4, after flased to 2.0.4 I had to Re-root.
                      Regards.
                        Some minor clarification:
                        3. press reset button and hold
                        5. release reset button after 1-2 secs
