Run any Android ROM from SD card
Great job!
wish I had such proliffic linux and shell scripting knoledgeI'm more of the copy/past/adapt kind of.
this scrit works great with both 4.2 and 4.4 roms. However I would still prefer my adaptation, because it allows me to interchange binaries from diferent roms e.g: tweaked boot + marvin kernel + finless sistem.img
I'm trying to do the same thing with an android 4.1 rom, but got no sucess so far. In some cases boot process hangs when zigote is already running but, t seems that it dies and restarts constantly
if I use a AP6210 kernel boot process stops right at the begnning:
[ 0.000000] sram_log: 4q ?& : 4q ?) !?, # 0q *! ! 3q @ 3q
Any ideas?
I what BlueZ stack back.
Originally posted by superceleron View PostThks
For Linux on RK3188 see http://www.freaktab.com/showthread.p...ng-your-device or https://plus.google.com/+IanMORRISON/posts/TTXkb7pX7SG
Originally posted by blueprint1972 View Postwish I had such proliffic linux and shell scripting knoledgeI'm more of the copy/past/adapt kind of.
Any ideas?
As to the message, unfortunately I've no idea.
need help with sd based booting
Hi linuxium,
Finally pulled some time to try this out. However, seeing blank screen even after waiting for about 10 mins on my Gm282 aka cx919ii. Few questions:
How long should I wait, since you mentioned it takes long for first boot?
Is this totally independent of Nand chip? I believe my Nand chip went bad since all my earlier attempts to flash said idb download failed. (I had done it successfully many times before that.)
Or does this require boot loader to be in Nand? I want to understand how this works..?
Also, in another thread I read that kernel needs to know that it has to look into SD card to load fs, so how would "any" Rom work unless it has such a tweaked kernel?
Sorry for lot of questions; newbie in Linux..
Hope to revive my dead device ��Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Linuxium, can you please reply to my questions? I would appreciate if you do. Thanks.Tronsmart Orion R68 Meta
Originally posted by ghanashyaml View PostLinuxium, can you please reply to my questions? I would appreciate if you do. Thanks.
Second, if you are running Linux on a 64-bit environment make sure you have 'ia32-libs' installed. This is because 'mkkrnlimg' is provided as a 32-bit binary from Rockchip hence the need for 'ia32-libs' if on 64-bit.
If you have problems installing 'ia32-libs' then you will need to use a 64-bit version of 'mkkrnlimg' which is available here https://github.com/phjanderson/Kernel-3188. To download and install this 64-bit version, first change directory to 'Tools' and in a terminal window enter 'mv mkkrnlimg mkkrnlimg.x86' and then 'wget https://github.com/phjanderson/Kerne...ster/mkkrnlimg' and finally 'chmod 755 mkkrnlimg' (note: I cannot stop hypertexting on the 'wget' command so make sure the full path is 'github.com/phjanderson/Kernel-3188/raw/master/mkkrnlimg').
Now run the script using the stock ROM for your device to test that everything works.
To answer your specific questions:
1. How long should I wait? First boot normally takes longer than a regular boot as the system is setting up various things. My stock ROMs include a boot animation meaning that you see some activity on the screen (like the Manufacturer's name and some moving graphic). A totally blank screen is unusual for a stock ROM but probably not unheard of. Initialization should be over after a couple of minutes and I would expect it to be completed well before 5 minutes.
2. Is this totally independent of Nand chip? Yes, on RK3188 devices it is totally independent to NAND.
3. Or does this require boot loader to be in Nand? As per the previous question, it does not look at the NAND.
4. Also, in another thread I read that kernel needs to know that it has to look into SD card to load fs, so how would "any" Rom work unless it has such a tweaked kernel? Basically there is a file within Android that "tells the kernel" where to look for the file system and partitions and this gets modified as part of running the script. Only this file needs to be modified and not the kernel.
You should first try using the stock ROM for your device as not all ROMs work on every device (due to hardware differences). In your case, assuming the SD card is correctly created, if stock ROM fails to boot it might mean your device is more damaged that you have assumed.
Thanks linuxium for answering all my questions! I appreciate your details answers. I will try them out and post back and I do hope my assumption is right.
it's work for me! with stock for k-r42 and "just XBMC from Lewy 1.1.1" !thank you Linuxium ! But not work if rom not have a "parameter" file(as wasser 1.0.4 (kitkat) for k-r42,.there is one section of memory 8gb). I found your alternative script for Roms with joinable "User" and "Data" , but this not works with 3188 : error - resource.img not found
P.s your alternative script works only with rk3288
UPDATE : I'm a little edit your script (however in Linux I'm a full zero, but I got) , I removed the string associated with resource.img , and I was able to unpack and run Wasser 1.0.4
This method solves the problem a shortage of built-in memory because sdcard is to become an internal sdcard
And , Linuxium thank you very much for this script!!!Last edited by pes1313; 19 May 2015, 19:04.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
Hi Linuxium, I know this thread is old but I wanted to bring this topic up for RK3368. Can this be done for RK3368?
Also, its pain to get the tool working with myriad of problems in SD card/USB card reader getting detected in VirtualBox and then in Ubuntu where I am trying this. So question is whether this tool can be ported to use windows batch commands or any console apps? It would be so much easier for many folks who struggle with Linux. I can do it if I knew/understand fully what all things the script is trying to do and if I can pull out some (midnight) time 😬.Tronsmart Orion R68 Meta
./create-android-sdcard htc_t018_public_ap6210_4.4.2_20150110.img
./create-android-sdcard: Is your SD card loaded as '/dev/sdc' (y/n)? n
./create-android-sdcard: Do you want to use a different device? y
./create-android-sdcard: Enter new device name? sdf
./create-android-sdcard: Is your SD card loaded as 'sdf' (y/n)? n
./create-android-sdcard: Enter new device name? /dev/sdf
./create-android-sdcard: Is your SD card loaded as '/dev/sdf' (y/n)? y
./create-android-sdcard: Unmounting partitions on '/dev/sdf' ... done.
./create-android-sdcard: Unpacking Android image 'htc_t018_public_ap6210_4.4.2_20150110.img' ... done.
./create-android-sdcard: Unpacking Android boot image ... done.
./create-android-sdcard: Formatting SD card '/dev/sdf' ... done.
./create-android-sdcard: Flashing bootloader 'sdboot_rk3188.img' to '/dev/sdf' ... done.
./create-android-sdcard: Updating partition table on '/dev/sdf' ... done.
./create-android-sdcard: Calculating partition sizes for '/dev/sdf' ... done.
./create-android-sdcard: Creating 'cache' partition as '/dev/sdf1' with size of 128 MB ...done.
./create-android-sdcard: Making 'ext4' file system for 'cache' partition on '/dev/sdf1' ... done.
./create-android-sdcard: Creating 'data' partition as '/dev/sdf2' with size of 4096 MB ... done.
./create-android-sdcard: Making 'ext4' file system for 'data' partition on '/dev/sdf2' ... done.
./create-android-sdcard: Creating 'metadata' partition as '/dev/sdf3' with size of 4 MB ... done.
./create-android-sdcard: Making 'ext4' file system for 'metadata' partition on '/dev/sdf3' ... done.
./create-android-sdcard: Creating 'system' partition as '/dev/sdf4' with size of 768 MB ... done.
./create-android-sdcard: Making 'ext4' file system for 'system' partition on '/dev/sdf4' ... done.
./create-android-sdcard: Creating 'user' partition as '/dev/sdf5' using rest of space on '/dev/sdf' ... done.
./create-android-sdcard: Making 'vfat' file system for 'user' partition on '/dev/sdf5' ... done.
./create-android-sdcard: Updating Android boot source ... grep: *: No such file or directory
done.
./create-android-sdcard: Updating Android system image ...sed: can't read system/etc/vold.fstab: No such file or directory
done.
./create-android-sdcard: Rebuilding Android boot image ... done.
./create-android-sdcard: Creating 'parameter.img' from 'parameter' ... done.
./create-android-sdcard: Flashing 'parameter.img' to '/dev/sdf' ... done.
./create-android-sdcard: Flashing boot 'boot.img' to '/dev/sdf ... done.
./create-android-sdcard: Flashing kernel 'kernel' to '/dev/sdf ... done.
./create-android-sdcard: Flashing system 'system.img' to '/dev/sdf4' ... done.
./create-android-sdcard: Removing unpacked Android image ... done.
./create-android-sdcard: Flushing buffers for '/dev/sdf' ... done.
./create-android-sdcard: Android SD card created on '/dev/sdf'.
anyone know whats causing this problem?
I guess its this part --
done.
but no matter what roms or what linux distro I try it on - always the same error
There are currently 1889 users online. 0 members and 1889 guests.
