Flash Bootloader.img
    Hi folks, is there a way to flash bootloader.img seperatly to my S802 box with default recovery ?
    i flashed OpenElec image without bootloader.img and that worked, but new versions have a Bootloader.img and for some reason those images wont flash.
    with my Rockchip i could easily flash those files, how about AMLOgic ?
    just like boot.img, is that also possible seperatly ?
    Home Cinema Setup Livingroom:
    50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
    Bedroom Media Setup:
    32" Philips LCD -
    KR-42 wasser rom
    I have not played with OpenElec is it a update.zip style package?
    If so that can be modified to remove flashing the bootloader.
    Also when you say it cannot be flashed, what do you mean? What happens?
      I think the update package was wrong of one of the OpenElec zip's
      normally i put it on USB, go into recovery and select update by EXT > UBOOT > and then select the zipfile.
      i have been playing around with other OpenElec releases and those flashed fine. so i think it was just a bad zip file wich was not properly signed or something
      So its all fixed, all i gotta do is wait for the OpenElec 5.0 rom now for MXIII 1GB Version
      32" Philips LCD -
      KR-42 wasser rom
