Kernel dev [RK3288]
    Kernel dev [RK3288]
    I've FINALLY got round to getting this box set up and compiling.
    I've built a kernel and tested it, a few errors but I'm sure it will be all smooth soon.
    I can see Mo123 has already done great work, is there anything extra needed? I'll build my kernel anyway but would be great to get an idea on priorities
    My first one will be optimizing DDR and CPU
    Donate to Finless
    Stable over clock of ddr3 and CPU would be sweet.
    The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
      Leolas has included nfs on his custom 3288 kernel ... a must have to a kernel
        I've isolated the two main bugs in my kernel act4486 and rk1000 i2c related.
        Once fixed I'll publish my alternative.
        Donate to Finless
          right on my friend.
            OK - all fixed.
            The DDR3 is set to 456 MHz and CPU to 1.8 GHz.
            What do we want? What has been tried?
            Donate to Finless
              "stock" 1800 CPU / 500 GPU / 456 DDR3 = 37,221 on Antutu @1920 x 1080 res
              "Overclock" 1992 CPU / 600 GPU / 600 DDR3 = 39,593
              I'll up the RAM to 667 and also try to compile with 4.9 xcompiler
              *edit* Frequency is clipped to 648 when I set 667. Antutu = 40,015
              Donate to Finless
                Finally have gotten my Firefly source code downloaded. Can you steer me to the proper files I need to modify for o/c. Set up with heat sink and cooling fan.
                cappybob
                  cappybob
                  In the device tree source, which makes life a lot easier
                  Donate to Finless
                    Doesn't boot with standard xcompiler, even after fixing a couple of always-inline errors it hangs on boot logo
                    Donate to Finless
                      First Test Kernel
                      OK, here's my first attempt. Test at your own risk. It will need a boot.img without kernel to work. You can test by checking the compile string in /antutu details. It will have my machine name (gargleblaster)
                      Details:
                      CPU - 2.0 GHz
                      GPU - 600 MHz
                      DDR - 650 MHZ
                      Antutu 5.3 = 40k
                      HDMI works fine but I think TV out needs work (can't test)
                      Added a few extras like NTFS, NFS, CIFS/Samba but can't add HDMI IN support as it doesn't exist in the source I have ??
                      download here
                      Donate to Finless
                        ... but can't add HDMI IN support as it doesn't exist in the source I have ?? ...
                        I think because it doesn't exist at the SoC... The so called "HDMI IN" seems to be nothing else than a switch at the HDMI which will be execute by an APP at android (if I'm not wrong, this is why it doesn't exist at the Linux at the moment)...
                        RK3288 Devices
                        - Overview BOX (LINK !)
                          The source Mo123 is compiling from has the driver (LT8641EX) but I'm compiling from Firefly which doesn't seem to have it even though it is mentioned on their website
                          Donate to Finless
                            Ahhh, ok, that means they handle it via I2C (and GPIO)....
                            But I don't understand why they talk about LT8641EX (I think it has to be at minimum LT8641SX but it is also HDMI 1.4 ... maybe the same driver) http://www.lontiumsemi.com/English/product1.asp
                            It try to identify the chip at this picture of the pcb (the best one I can find) and it seems to be the SX
                            THX for the information
                            RK3288 Devices
                              Details:
                              CPU - 2.0 GHz
                              GPU - 600 MHz
                              DDR - 650 MHZ
                              Antutu 5.3 = 40k
                              Good job! Nice to see increasing support for our boxes.
                              Does it overheat, or is the voltage tweaked too? Can it be safely run without active cooler?
                              You should get in touch with mo123 or finless to make one kick-ass rom
                              btw, I thought the gpu is clocked @700mhz by default. Obviously not.
                              Thanks and keep up the good work.
