UPDATE 06 December 2014: online again - http://www.tronsmart.com/support/dow...smart-vega-s89
109k4 ROM was removed from Tronsmart.com (update - online again)
They removed 109k4 firmware download for Tronsmart Vega S89 Elite/Standard and S89-H from the Support section without any explanations. It happened on 28.11.2014. Does someone know why?
UPDATE 06 December 2014: online again - http://www.tronsmart.com/support/dow...smart-vega-s89Last edited by lawin1; 06 December 2014, 17:43.Tags: None
Highly doubt it its more likely just the 110k bluetooth update.
Still you never know so its always worth trying and its easy to go back to other firmwares.
Its basically a copy of the beelink with some tronsmart logo's.Last edited by Magnus33; 06 December 2014, 20:12.Mk802IV Neomode 1.9a original rom 720p
Originally posted by manu81 View PostToday is online again. Any did can test it? Is a new version?
For 109k4, recommend to use OTA or SD card to update.Coupons Updated Every Day: https://bit.ly/2RnbHUi
Guest
Guest
Changelog:
1.Update xbmc to 13.4 version;
2.Update Skype;
3.Ethernet MAC (No need to modify Ethernet MAC by tool ,it can be produced by FW automatically and be unique)
4.UPdate DLNA&Airplay;
6.Fix some issues on the streaming APP,such as Hulu,BBC News,vudu…
7.Many fixes on multimedia playing..
8.Other little tweaks.
Originally posted by manero View Post
Originally posted by Pinocan View PostI have Mbox S82B. Can I flash the standard/elite rom on my Mbox S82B?
Same firmware for both with boot and picture images added for either model being the only difference.
Although tronsmart does now and then do something stupid.
Also the recovery is a little messed up so flashing from the reset buttion on bootup may not work.
You can flash from the update in settings or the ota flasher in the apps if you downloaded and unziped the update to the sd card.Mk802IV Neomode 1.9a original rom 720p
There are currently 5760 users online. 1 members and 5759 guests.
