or is there a way to make ps3 or xbox controller to work ?
gamepad for bluetimes m8 box
You must use version 8 or above for it to workPlease consider making a Donation to freakTab
Originally posted by blinkone View Postps3 controller will work with it now you must use this
Originally posted by darkaaaa View Postit did not work i try the letest ver and btw my box rootedPlease consider making a Donation to freakTab
Originally posted by darkaaaa View Posti told you im rooted and i tested sixaxis 0.8.1 and it did not work
thanks anywayRK3288 Devices
- Overview BOX (LINK !)
thanks anyway
What fault is it showing wil it connectPlease consider making a Donation to freakTab
maybe you should consider some physical gamepad, like tronsmart mars g01 or g910.
EricLooking for developers
Originally posted by blinkone View PostSorry to hear its not working for you maybe you have a fake ps3 controller..sixaxis now works on all my devices beelink m8, minx x8-h, cx 919, tronsmart orion r28, mk809ii
btw im using m8 moudel k200 bluetimes if you want to tell that its works
There are currently 3913 users online. 0 members and 3913 guests.
