MK809II use as Miracast Device (such as Wifi Display) Possible?
    Hi
    First of all, I have to say I´m a real noob, i even have an old Smartphone (Cat B15 Android 4.1).
    I got a MK809II Stick from my friend.
    I already flashed the Finless1.7a firmware and the device works great.
    Now I´m wondering, if this device could be used as a kind of miracast dongle (except Wifi Display)
    Is it possible to add it into the rom?
    I don't know Miracast server software available other than WifiDisplay. But for similar purpose you can use eHomeMediaCenter or other DLNA renderer implementations (BubbleUPNP, for instance). And also there is EZCast Screen (don't know what protocol they use)
    You always can install programs from Play Market
      Hi
      thanks, I just flashed Finles 2 Firmware with Wifi Display integrated.
      Everything works now
