m809iii wifi 8723 full xbmc root download 1080p
    MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
    for video https://www.youtube.com/watch?v=NKjJLztBbSc
    which android version?
      MK809III,UH007B_8723bs_4.4_1080_20140924.rar
      Currently Inactive on Freaktab.com
      I use: MK903V | MELE F10 Deluxe | Roku 3600R
      RIP: MK808b | MK809III | PIPO M9 Pro
        so the one I mentioned in a post earlier asking about it lol
          I assume this will need a vsync patch, can someone extract the boot and kernel and patch it?
            I figured out how to patch the kernel, working on overclock, but can anyone confirm that this ROM is rooted and properly rooted for 4.4.x? I am learnt out and can't take on rooting, too.
              hi
              i tested video have
                but
                only warming up .all android box heating for make modefie alimium on chipset and ram
                then ok
                  hi
                  install and see latest version perfect work
                    I will be flashing this rom, debloating, extracting the boot and kernel and then overclocking the gpu and ram. Since it is 4.4 I read that it does not require vsync. Once I can confirm this, I will be uploading the rom package as best as I can. No frills here, just a simple upgrade/fix. Hopefully it is rooted, otherwise it will take a little longer.
                      cool looking forward to it... drop me a pm when you have done.
                        I installed it to my stick and it is for the most part free of any useless apps and is rooted and runs well.
                        I am working on the OC kernels, but I need to test these to be sure they work. The overclockomatic tool shows two gpu or ram tables, I'm not certain which to use, so I may not be doing anything when I run it.
                        The stick has an RK3188T chip but this firmware runs at 1.6ghz. I think that is a safe place to start. Running the kernel_cpustock_gpu798h_ddr720.img and have no problems so far. I'll upload the kernels when I get a chance.
                        You cannot downsize the screen resolution, so if you want a 720 rom, you can't get it. I don't really need 1080 but if that's what I have to do, I can live with it.
                          Does BT work?
                          Does this firmware support rotation? e.g. it has an option to allow the App to rotate at will?
                          The stock firmware is the only firmware I know that has working BT. It has 2 limitations - no 1080p and no rotation. Sounds like 1080p is not an issue anymore.
                            Originally posted by mongkok View Post
                            Does BT work?
                            I will test Bluetooth to make sure it works. How can I test screen rotation?
                              Does BT work? Does this firmware support rotation? e.g. it has an option to allow the App to rotate at will? The stock firmware is the only firmware I know that has working BT. It has 2 limitations - no 1080p and no rotation. Sounds like 1080p is not an issue anymore.
                              try some of the custom roms here, Bluetooth is working for me!!!
