kit kat location services
That must have gotten left out of the stock firmware build for some reason. It's a setting in SettingsProvider.apk...but I can't look at it until the weekend.Randy
Guest
Pull down the upper right menu, there you find location. Pressing long changes on /off.
Gesendet von meinem M9pro mit Tapatalk
location services
thanks, you are correct top right hand corner, long push and on it comes, however google maps still cant find my location, not sure if it did before i upgraded though, i have the m9 wifi only model, i would of thought it would locate through the wifi. perhaps i am talking rubbish
There are currently 2424 users online. 0 members and 2424 guests.
