Pipo p4 GPS not working
Make sure Location Services is turned on in settings and Device only or Device + WiFi selected. The first fix will take extra time so don't worry if it shows no satellites for a while, they should show up. It's working for me on my P4 with Rilely ROM 2.0
Sent from Tapatalk on my Pipo P4 running RR 2.01
Originally posted by Billcnz View PostMake sure Location Services is turned on in settings and Device only or Device + WiFi selected. The first fix will take extra time so don't worry if it shows no satellites for a while, they should show up. It's working for me on my P4 with Rilely ROM 2.0
Re: Pipo p4 GPS not working
Originally posted by k@non View Postyes i used , did you know one more ? because its still not working
Originally posted by Billcnz View PostThere are other GPS apps but they probably won't help if GPS is not enabled in the ROM. You could try Riley ROM or wait for a later stock ROM.
There are currently 2019 users online. 1 members and 2018 guests.
