I have an Acer T272HL bmjjz. It is a 27" touch display that uses a USB for the HID and is Windows 8 10 point touch compatible.
Ultimately, I would just like to have an android device hooked up to the display and working properly. If that means buying a different device, I'm fine with that as well. I have read all different threads about firmware, compiling kernels, installing IDC files. All of which I'm fine with, I am just trying to find out IF it is even possible before I spend hours trying to muddle through it.
At the moment, I have a basic RK3188 android TV stick from DigitalSignage.com. It seems to have some proprietary software that is making it difficult to access/root.
FYI - here is some info from my android device:
kernel 3.0.36+
build rk31sdk
vendor info: rk3188_r-box_android4.2.2-sdk_v1.0.0_130514
Here is what I got from the USB port when the display HID was connected:
Product ID: 0x0610
Vendor ID: 0x05e3 (Genesys Logic, Inc.)
Version: 70.17
Speed: Up to 480 Mb/sec
Manufacturer: GenesysLogic
Location ID: 0x14200000 / 9
Current Available (mA): 500
Current Required (mA): 100
The touch screen works to some degree. When using 5 fingers I'm able to drag the 'circle' cursor around the screen. A 6th touch is a 'click' and sometimes with all 10 fingers I'm able to drag things - but not very well.
Any help would be greatly appreciated.
Charlie
