Additional Info
Function description | Connect to a TV, this is a media box | |
Connect to a monitor , this is a mini PC | ||
System | CPU | Intel Baytrail Z3735F or Z3736F |
CPU speed | up to 1.83Ghz(Z3735F) or 2.16GHZ(Z3736F) | |
RAM | 2GB DDR 3L | |
Operation System | Windows 8.1 with Bing | |
I/O ports | Micro SD slot | x1 |
USB port | Type A USB*4 | |
LAN port (RJ45) | yes | |
AV out | Audio out | |
optical Audio | No | |
HDMI output | yes | |
Communication | Wifi | 802.11b/g/n |
Bluetooth | Yes | |
Power | Adaptor | 5V 2A |
Physical Characteristics | Material | metal |
Weight | 440g | |
Dimensions | 188*129*25.6mm | |
Accessories | AC adapter | x1 |
