please !
God, help me!
Maybe these will help...
http://www.freaktab.com/forumdisplay.php?136-Beelink-Tronsmart-T428-MK908-etc
Hi guys: Here is the newest stock firmware for Tronsmart MK908, this firmware can work on V3 and V5 board. (V5 is the lastest board, and now all of the Tronsmart MK908 we shipped are V5 board). PS: how to check if you are V3 or V5 board, now the only method to check is […]
Kernel Source
Hello,
Try it with this Sources --> https://github.com/Dee-UK/D33_KK_Kernel.
It is Kernel Source for Android 4.4.
With these Sources you should get a Booting Kernel for Shure.
Regards
Neomode
Thanks !
Regards
Neomode
My log
2031967 Starting kernel...@0x60408000
[ 0.883924] console [ttyS2] enabled, bootconsole disabled
[ 0.973708] rk_serial rk_serial.2: membase 0xf70c8000
[ 0.978852] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[ 1.073715] rk_serial rk_serial.3: membase 0xf70d0000
[ 1.079059] [drm] Initialized drm 1.1.0 20060810
[ 1.083965] Rockchip ion module(version: 1.0) is successfully loaded
[ 1.094174] loop: module loaded
[ 1.097354] Android kernel panic handler initialized (bind=kpanic)
[ 2.105066] PPP generic driver version 2.4.2
[ 2.109656] PPP Deflate Compression module registered
[ 2.114861] PPP BSD Compression module registered
[ 2.133187] PPP MPPE Compression module registered
[ 2.138044] NET: Registered protocol family 24
[ 2.142676] usbcore: registered new interface driver asix
[ 2.148199] usbcore: registered new interface driver cdc_ether
[ 2.154204] usbcore: registered new interface driver dm9620
[ 2.159839] usbcore: registered new interface driver SR9700_android
[ 2.166208] usbcore: registered new interface driver net1080
[ 2.171929] usbcore: registered new interface driver cdc_subset
[ 2.177941] usbcore: registered new interface driver zaurus
[ 2.183533] cdc_ncm: 04-Aug-2011
[ 2.186811] usbcore: registered new interface driver cdc_ncm
[ 2.192494] Rockchip WiFi SYS interface (V1.00) ...
[ 2.197541] Initializing USB Mass Storage driver...
[ 2.202483] usbcore: registered new interface driver usb-storage
[ 2.208528] USB Mass Storage support registered.
[ 2.213253] usbcore: registered new interface driver usbserial
[ 2.219205] USB Serial support registered for generic
[ 2.224350] usbcore: registered new interface driver usbserial_generic
[ 2.230890] usbserial: USB Serial Driver core
[ 2.235313] USB Serial support registered for GSM modem (1-port)
[ 2.241393] usbcore: registered new interface driver option
[ 2.246986] option: v0.7.2:USB Driver for GSM modems
[ 2.251988] USB Serial support registered for usi-modem
[ 2.257299] usbcore: registered new interface driver usi-modem
[ 2.475072] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
[ 2.479803] usb20_otg usb20_otg: DWC OTG Controller
[ 2.484794] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[ 2.492075] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[ 2.497610] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
[ 2.504384] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.511202] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.518480] usb usb1: Product: DWC OTG Controller
[ 2.523206] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
[ 2.528993] usb usb1: SerialNumber: usb20_otg
[ 2.533855] hub 1-0:1.0: USB hub found
[ 2.537621] hub 1-0:1.0: 1 port detected
[ 2.543999] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xf7180000
[ 2.762721] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[ 2.767367] usb20_host usb20_host: DWC OTG Controller
[ 2.772465] usb20_host usb20_host: new USB bus registered, assigned bus number 2
[ 2.779925] usb20_host usb20_host: irq 49, io mem 0x00000000
[ 2.785661] DWC_OTG: Init: Port Power? op_state=1
[ 2.790373] DWC_OTG: Init: Power Port (0)
[ 2.794471] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.801276] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.808546] usb usb2: Product: DWC OTG Controller
[ 2.813259] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
[ 2.818968] usb usb2: SerialNumber: usb20_host
[ 2.823791] hub 2-0:1.0: USB hub found
[ 2.827555] hub 2-0:1.0: 1 port detected
[ 2.832839] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.839805] android_usb gadget: Number of LUNs=2
[ 2.844448] lun0: LUN: removable file: (no medium)
[ 2.849334] lun1: LUN: removable file: (no medium)
[ 2.854507] android_usb gadget: android_usb ready
[ 2.859462] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
[ 2.866797] usbcore: registered new interface driver xpad
[ 2.872874] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 2.882100] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 2.891330] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 2.900539] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 2.909788] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 2.919050] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 2.928406] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 2.937723] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 2.947049] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 2.956280] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 2.965505] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 2.974752] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 2.984077] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 2.993396] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.002715] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.012039] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.021379] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.030749] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.039677] rtc: hym8563_init_device: read CTL2 err
[ 3.044902] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.054115] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.063325] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.072652] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.081998] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.091327] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.100251] rtc_hym8563 1-0051: clock/calendar information is no longer guaranteed
[ 3.108728] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.118511] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.128302] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.138186] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.148071] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.157977] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.167747] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.177540] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.187310] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.197238] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.207124] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.213675] usb 2-1: new low speed USB device number 2 using usb20_host
[ 3.223681] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.233271] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.242884] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.252476] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.261703] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.270906] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.280154] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.290067] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.299953] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.309836] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.319012] using rtc device, rtc_hym8563, for alarms
[ 3.323967] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
[ 3.330898] i2c /dev entries driver
[ 3.335119] lirc_dev: IR Remote Control driver registered, major 251
[ 3.341596] IR NEC protocol handler initialized
[ 3.346177] IR RC5(x) protocol handler initialized
[ 3.350975] IR RC6 protocol handler initialized
[ 3.355566] IR JVC protocol handler initialized
[ 3.360104] IR Sony protocol handler initialized
[ 3.364741] IR RC5 (streamzap) protocol handler initialized
[ 3.370322] IR LIRC bridge handler initialized
[ 3.374808] Linux video capture interface: v2.00
[ 3.379535] usbcore: registered new interface driver uvcvideo
[ 3.385331] USB Video Class driver (v1.1.0)
[ 3.389577] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
[ 3.394860] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 3.400914] rk29-wdt rk29-wdt.0: starting watchdog timer
[ 3.406807] device-mapper: uevent: version 1.0.3
[ 3.411692] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: [email protected]
[ 3.420368] Bluetooth: HCI UART driver ver 2.2
[ 3.424891] Bluetooth: HCI H4 protocol initialized
[ 3.429701] Bluetooth: HCILL protocol initialized
[ 3.434771] [imoseyon] interactiveX enter
[ 3.438824] cpuidle: using governor ladder
[ 3.442936] cpuidle: using governor menu
[ 3.450773] usb 2-1: New USB device found, idVendor=13ba, idProduct=0017
[ 3.457617] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.464773] usb 2-1: Product: Generic USB K/B
[ 3.499898]
[ 3.499908] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc0]
[ 3.499997] .Line3965..The End of SDMMC-probe Ver.5.05 The last modify date is 2013-05-08. [sd_mmc]
[ 3.500363] .Line3965..The End of SDMMC-probe Ver.5.05 The last modify date is 2013-05-08. [sdio]
[ 3.526934]
[ 3.526941] =================
[ 3.526952] mmc_rescan..1831.. ====find no SDMMC host. [mmc0]
[ 3.537331]
[ 3.537339] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 3.549115] input: Generic USB K/B as /devices/platform/usb20_host/usb2/2-1/2-1:1.0/input/input1
[ 3.558381] generic-usb 0003:13BA:0017.0001: input: USB HID v1.10 Keyboard [Generic USB K/B] on usb-usb20_host-1/input0
[ 3.569287] rk29_sdmmc_change_clk_div..1961.. newDiv=42, newCLK=294Khz [sdio]
[ 3.582202] input: Generic USB K/B as /devices/platform/usb20_host/usb2/2-1/2-1:1.1/input/input2
[ 3.591358] generic-usb 0003:13BA:0017.0002: input: USB HID v1.10 Mouse [Generic USB K/B] on usb-usb20_host-1/input1
[ 3.605309] usbcore: registered new interface driver usbhid
[ 3.610949] usbhid: USB HID core driver
[ 3.615370] logger: created 256K log 'log_main'
[ 3.620092] logger: created 256K log 'log_events'
[ 3.625094] logger: created 256K log 'log_radio'
[ 3.629880] logger: created 256K log 'log_system'
[ 3.657010] asoc: hdmi-audio-codec <-> rk29_i2s.1 mapping ok
[ 3.663332] ALSA device list:
[ 3.666376] #0: ROCKCHIP HDMI
[ 3.669738] GACT probability NOT on
[ 3.673308] Mirror/redirect action on
[ 3.677028] u32 classifier
[ 3.679757] Actions configured
[ 3.683190] Netfilter messages via NETLINK v0.30.
[ 3.688014] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.694840] ctnetlink v0.93: registering with nfnetlink.
[ 3.700253] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 3.707369] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 3.713906] xt_time: kernel timezone is -0000
[ 3.718724] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.724443] arp_tables: (C) 2002 David S. Miller
[ 3.729175] TCP cubic registered
[ 3.732433] Initializing XFRM netlink socket
[ 3.737747] NET: Registered protocol family 10
[ 3.743524] Mobile IPv6
[ 3.746102] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.751741] IPv6 over IPv4 tunneling driver
[ 3.757575] NET: Registered protocol family 17
[ 3.762106] NET: Registered protocol family 15
[ 3.766948] Bluetooth: RFCOMM TTY layer initialized
[ 3.771898] Bluetooth: RFCOMM socket layer initialized
[ 3.777144] Bluetooth: RFCOMM ver 1.11
[ 3.780929] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.786293] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.792477] NET: Registered protocol family 35
[ 3.797151] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.801691] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.807118] [BT_RFKILL]: ** disable irq
[ 3.811227] [BT_RFKILL]: bt shut off power
[ 3.843674] [BT_RFKILL]: ap6210 device registered.
[ 3.848580] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 3.856455] Registering SWP/SWPB emulation handler
[ 3.861679] usb detect inited by board_usb_detect_init, disable detect by bvalid irq
[ 3.869958] ddrfreq: change freq to 222 MHz when normal
[ 3.875299] ddrfreq: verion 2.4 20130427
[ 3.879263] ddrfreq: normal 222MHz video 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
[ 3.890149] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 2...
[ 3.900108] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 1...
[ 3.910143] i2c i2c-1: No ack, Maybe slave(addr: 0x51) not exist or abnormal power-on, retry 0...
[ 3.919096] rtc_hym8563 1-0051: hctosys: invalid date/time
[ 3.925346] usbcore: registered new interface driver snd-usb-audio
[ 5.933718] Warning: unable to open an initial console.
[ 5.940137] Freeing init memory: 4752K
[ 5.961473] gp_rknand_info = : 0xed2e4500
[ 5.965808] request IRQ_NANDC irq , ret=0.........
[ 5.970770] FlashCopyProgBuf1=0xc198e000
[ 5.974766] ATime: 40 ns AHB: 148 timming: 1081
[ 5.979324] No.1 FLASH INFO:ff ff ff ff ff
[ 5.983442] No.2 FLASH INFO:ff ff ff ff ff
[ 5.987574] No.3 FLASH INFO:ff ff ff ff ff
[ 5.991692] No.4 FLASH INFO:ff ff ff ff ff
[ 5.995821] gBootMedia = 2 gSdmmcFwPartOffset =2000!
[ 6.000817] EMMC Ver 20121108!
[ 6.003900] CardId = 2
[ 6.157570] rk29_dma_set_buffdone_fn
[ 6.161165] EmmcBus_khz = 37125
[ 6.164334] SDM_Init OK
[ 6.178287] SdmmcInit UserCapSize: 0xe70800
[ 6.182498] SdmmcInit ret = 0!
[ 6.185601] rknand_buffer.c version: 4.38 20121130!
[ 6.190817] 3 cmdlinepart partitions found on MTD device rk29xxnand
[ 6.197170] Creating 3 MTD partitions on "rk29xxnand":
[ 6.202353] 0x000000400000-0x000001400000 : "boot"
[ 6.208605] 0x000001400000-0x000002400000 : "kernel"
[ 6.214646] 0x000002400000-0x0001cdd00000 : "system"
[ 6.331175] udevd[101]: starting version 175
[ 18.563666] DWC_OTG: ********vbus detect******************************************** *
There are currently 3758 users online. 9 members and 3749 guests.
