First install instructions
* As really first thing install one of the available customs recoveries (CWM or TWRP)
* Power off your device and unplug the AC power cord.
* Get the latest available ROM and GAPPS version from the links below and copy them to a MicroSD card.
* Now insert the MicroSD card in your STB.
* Plug the AC power cord while you keep pressed the little reset pinhole (located on the bottom of the device) for 10 seconds (just count slowly to ten and it will be good).
* Once the device has booted to recovery perform a factory reset and flash the ROM's zip for first followed by the GAPPS zip.
* Reboot and enjoy CyanogenMOD.
Update instructions
* Enable "Developer options" following this tutorial and from it enable the "Reboot to recovery" option.
* Bring up power menu by keeping pressed the power button on the STB for a couple of seconds (or pushing F5 if you have a keyboard plugged in) and select "Reboot -> recovery".
* Once the device has booted to recovery flash the ROM's zip for first followed by the GAPPS zip.
* Reboot and enjoy your updated CyanogenMOD.
Downloads
* ROM 2014-12-09
* GAPPS 2014-06-06
Screenshots
