3D graphics (using Mali drivers) aren't included and I'm not aware of anyone who has included them in a RK3288 build.
Use Windows to create an SD card so you can run Linux on a RK3288 device
Originally posted by linuxium View PostUnfortunately hardware graphics acceleration isn't available anywhere so the last Ubuntu with Unity is stuck at version 12.04.
Originally posted by dancar View PostAny insights as to why? Patent issues? Optimization secrets? Don't want the open source nightmare of having to share too much?
AFAIK ARM haven't yet released the Mali-T764 drivers publicly whereas Rockchip only issue the drivers as binary blobs for Android.
Hi linuxium
Just a quick question you may be able to shed light on, I tried your windows method of running linux and have since reformatted my sdcard (fat32) and put my backed up data back on bu the thing is I am using Wasser-Firmware-V2-0-3 and my device wont boot with the SD card plugged in like its trying to boot from it, once ejected I am able to boot fine??
I'm not sure if wasser's 2.0.3 img also flashes the RK3288Loader_uboot_V2.17.02 off wasser's img, so I made an package to only flash the bootloader... I hope this will work and help...
(you will also find a RK3288Loader_uboot_V2.15.02_110k4.bin at it)RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostI'm not sure if wasser's 2.0.3 img also flashes the RK3288Loader_uboot_V2.17.02 off wasser's img, so I made an package to only flash the bootloader... I hope this will work and help...
RK3288Loader_uboot_V2.17.02_wasser.bin give me the same issue 'RK3288Loader_uboot_V2.15.02_110k4.bin' allows me to boot with sdcard inserted.
Is my sdcard retaining some boot sector information maybe?
14.10 at R89
14.10 (ubuntu1410-linux-rk3288-sdcard.img) at R89 (netxeon v2: 2/16GB AP6210 111k4)
- [Restart...] doesn't work: black screen -> lose HDMI-signal -> LED blue...
=> after power off (hard) the system starts at your logo (longer shown as normal) and after a while I see action at HDMI (TV off / on / change resolution) but only get a black screen...
- [Shut Down...] => the same...
=> Hard power off / on (un/plug PSU) => everything is nearly fine, because I can lose data this way
BTW: I got panic at the first moment I saw your screensaver
- [System Settings...] doesn't start...
Because I got the massage that network is disabled:
sudo nano /etc/network/interfaces
Code:auto eth0 iface eth0 inet static address 192.168.2.223 netmask 255.255.255.0 gateway 192.168.2.100 dns-nameservers 192.168.2.100 pre-up ifconfig eth0 hw ether e2:38:61:79:76:74
Why do I see /dev/mmcblk0 and 1?
Is 0 the internal eMMC/NAND?
At 1 I only see one partition (mmcblk1p1):
- Start: 139265
=> Is this the rootFS?
If yes, is it able to use one of (your) other rootFS by dd to /dev/mmcblk?p1 or /dev/sd?1?
E.g.:
http://download.opensuse.org/ports/a...urrent/images/ (armv7hl)
=> e.g. http://download.opensuse.org/ports/a...-Build49.2.tbz
For those who want to use it headless, you should have a look at
http://www.freaktab.com/showthread.p...l=1#post151965 3.) ...
(I use a text-file at a USB pen drive, because I'm a friend of copy&paste)
I got the VNC running and I got a connection, but I got a lot of messages I can't remember at 12.0x and I only get a grey screen at the PC... BUT it's enough for today...RK3288 Devices
BTW:
I see your test NAND vs. SD vs. USB
Which RK3288 BOX?
Code:1. First I set the governor to 'performance' (echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor) 2. For the write test I use the command 'dd if=/dev/zero of=speedtest bs=1M count=1000 oflag=direct conv=fdatasync' 3. For the read test I use 'dd of=/dev/null if=speedtest bs=1M count=1000 iflag=direct'
How do you realise to get the rootFS strating/running from USB (I think you bootup kernel and initramfs from SD)?
(I actually ordered a '32GB Samsung EVO Class 10 UHS-I Micro SD' which seems to be a beast http://freaktab.com/forum/tv-player-...054#post391054)
OK also meanwhile I found this https://plus.google.com/+IanMORRISON/posts/R5jbR3aZbZm
(BTW: I hate this G+ ... I can't handle it... it drives me creasy...)
I'm not sure I've followed everything you've posted so I'll embed my comments below in RED ...
Originally posted by no_spam_for_me View Post14.10 (ubuntu1410-linux-rk3288-sdcard.img) at R89 (netxeon v2: 2/16GB AP6210 111k4)
So it has booted (as you've seen my logo) but seems that it cannot find the RFS
So now it works?
Do you mean logo as the screensaver should be standard Ubuntu offerings?
So Ubuntu is running and when you select 'System Settings' nothing happens?
That doesn't sound right as from memory you should only see the SD card (/dev/mmcblk1) ...
- Start: 139265
Yes
E.g.:
It is easiest to create the SD card using the script and a different RFS rather than modifying a loaded RFS.
Grey screen/black screen/missing Unity etc with VNC are all common problems. Easiest way is to install LXDE then edit your .vnc/xstartup file and replace the last line with 'startlxde' and then restart VNC.
Again I'll embed my comments below in RED ...
Which RK3288 BOX?
Orion Meta R28
Yes, the CPU frequency governor functionality is the same in both Android and Ubuntu - I set it to 'performance' which sets the CPU to the highest frequency allowed.
(I actually ordered a '32GB Samsung EVO Class 10 UHS-I Micro SD' which seems to be a beast http://www.freaktab.com/showthread.p...l=1#post269873)
I think you answered your own question?
If you click on my name in G+, you get to see all my posts on a single page, which makes reading them a bit easier.
So now it works?
not really, because I don't like hard power off/on by PSU...
I only saw the test-screen and a flame-symbol in the middle of the screen and at the first moment I thought the system crashes
yes...
But I see it, whatever the reason...
Of cause I want to modify it at another system (not booted this system e.g. place the SD at a USB reader)...
Which means only at VNC the LXDE is running? Or do I replace the Unity? btw: is it unity at 14.10? If I remember correctly at the rk3188 running your 12.04 I hadn't any problem (but I don't like the GUI at 12.04)....
That's nice! And noop?
Rightbut hadn't any deeper look at it at the moment (RFS at USB)....
RK3288 Devices
No net
Everything works perfectly , thanks for the great contribution , well explained . The problem is that the wifi does not work, and neither have achieved that with the image of ubuntu 12.04 I run the network connection , so I do not have internet . I 'm tinkering on a rikomagic 902II , and no way to access the Internet by connecting eth0 ... A Somebody else 's happening?
I didn't test the WiFi, and I don't know which WiFi chips will be supported by linuxiums kernel... I know the different netxeon PCB's use the AP6210 or AP6335 chip (one of them has linuxium), but, if I'm not wrong, your device with the htc pcb use the AP6330 chip...
Also I don't know, if your pcb use another "address" to connect to the LAN chip (I have no idea, because if people port an android-rom from another device to there device they normally use the kernel.img (wifi-driver) and the recources.img (I think contains e.g. this LAN chip "address") of there device)....RK3288 Devices
There are currently 2840 users online. 0 members and 2840 guests.
