Last time, I flashed my CS918 box using the wrong or unsuitable ROM, and for the past few weeks, I'm having difficulties in finding the suitable ROM for this device. The images of the Printed Circuit Board (PCB) and the About Device page are as shown below:
The PCB picture is almost the same as shown in the page below:
Based on the page in the link below, :
the possible stock firmware for the PCB image I've shown above would be:
I've tried it, but no luck. The device keeps getting reboot loops. I've tried almost 20 ROMs, but still, no luck.
This Android 4.4.2 ROM from the link below can be used with my CS918 box as shown in the pictures above, but the WiFi and Bluetooth is not working. The Ethernet is working though.
Here are some hardware specifications of the box:
Chipset - RK3188
RAM - 2GB
NAND Flash - 8GB
GPU - Mali 400
WiFi and Bluetooth chipset - RTL8723AS
After a few weeks I tried to look for the suitable ROM for the device, I asked the supplier to give me the STOCK ROM. The stock ROM is Android 4.2.2 though. You can download it from the link below:
CS918 RK3188 RTL8723AS WIFI BLUETOOTH ANDROID 4.2.2 LOADERV213 06072014.rar (325.56MB)
The stock ROM solved my problem anyway. The device can be used normally. All of the original functions are working, but, can anyone provide Android 4.4.2 ROM for this device I've shown above with working WiFi and Bluetooth? Maybe anyone can just add the RTL8723AS driver to the Android 4.4.2 ROM l mentioned in the link above. It was just a suggestion. Anymore suggestions will be much appreciated.
I'm looking forward to hear more about this from you guys.
Thanks.
