Creating Compatibility Zips - AOKP
Originally posted by drywall420 View PostHey I'm just testing now. Hard part is going to be deciding later which one to use...
BTW, I'm coming up with nothing in regards to script.bin so unless I can figure out how to incorporate those two files with the ROM I can't do anything other than create a generic live suite image...I *think* they were compiled by William but it's definitely beyond my scope of knowledge at this point :-(
UPDATE: And RIGHT as I typed and sent this I figured out where they go, so now all I need to do is figure out where the compatibility file goes...
UPDATE 2: I think I got it! I don't know how to incorporate that file but I CAN just run this in ubuntu and have it modify the build.prop directly...keep your fingers crossed this works-I might just have a unified Live Suite image for you guys to test shortly...
Originally posted by drywall420 View PostCM9 Nightly works too!Elektrik I know you love me.
https://docs.google.com/folder/d/0B4...2ZuWTBjSER5X3M
Originally posted by elektrik View PostBTW, I'm coming up with nothing in regards to script.bin so unless I can figure out how to incorporate those two files with the ROM I can't do anything other than create a generic live suite image...I *think* they were compiled by William but it's definitely beyond my scope of knowledge at this point :-(
Originally posted by drywall420 View PostFingers crossed. Would be nice if one of us doesn't have to write up CWM instructions for all these roms.
Originally posted by drywall420 View PostIsn't that something a CWM backup would do?
Originally posted by drywall420 View PostI have ADB installed just need instructions...
on the PC:
> md _bootfs
> cd _bootfs > adb shell
$ cd / $ mount -o remount,rw -t ext4 /dev/root /
$ mkdir bootfs
$ mount -t vfat /dev/block/nanda /bootfs
(Control-C: exit adb shell)
> adb pull /bootfs
Then zip up the contents so I can download.
Originally posted by elektrik View PostOk:
on the PC:
> md _bootfs
$ mkdir bootfs
> adb pull /bootfs
Originally posted by drywall420 View PostHope this is it!:
https://docs.google.com/file/d/0Byw2...RNcWpZY3c/edit
Originally posted by elektrik View PostPERFECT!
There are currently 4951 users online. 2 members and 4949 guests.
